Old 01-11-2016, 10:55 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Hedman Mid Length
Has anyone used the Hedman Husler mid-length LS swap headers on a squarebody?
I'm looking at header options and I don't want to spend $500+ to get headers and these look like a viable option. I am pretty low as well so I think these will help me keep my exhaust tucked away.
Any other options for the lowered squarebody that keeps the collectors up in the frame rails?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-12-2016, 06:14 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Hedman Mid Length
I used a set of Hooker streetrod shorties, on my 69 LS swap...Should also work on the square body trucks. painted , the headers were around $ 250, plus a set of stainless mandrel tubes ($90 through Speedway Motors). They tuck up tight, & will fit mechanical clutch linkage ....if you need to go that route. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-12-2016, 02:45 PM   #3
jamesjones
Freakin Awesome!
jamesjones's Avatar
If you're going to consider any shorty type header I'd just run ls3 manifolds. You should be able to find some for around $100 and just get them coated at your local shop.
Mine isn't a square body but you can see how tight they hug the block...
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 01-12-2016, 04:43 PM   #4
softballnrd27
I'm considering some pacesetter headers for 99-06 truck. I had a set of 99-06 Calspeed headers in my hand and they were very close to fitting
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-12-2016, 05:32 PM   #5
UATahoe
I just purchased these exact headers to go on my 87 ls1 swap. I will let you know how they do once I get them in.
UATahoe is offline   Reply With Quote
Old 01-12-2016, 08:59 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got the Hedman 73-87 LS mid's in my '66. I trimmed my rail a small amount because unless I go with solid mounts or a motor plate, my junk torques itself just close enough to the rail to make me nervous. If your ok with 1/8th clearance, then thats not required.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
