Old 01-11-2016, 01:02 PM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
hood wobbles.........
whats up brothers.... I have a 68 im working on... when driving the hood wobbles in the middle is there a support that I can put in the middle if not im thinking of fabing some up.....any help is much appreciated
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-11-2016, 01:05 PM   #2
Sklptrljay
Sklptrljay's Avatar
Re: hood wobbles.........
Do you have the rubber pieces in between the hood skin and the braces underneath?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 01-11-2016, 01:09 PM   #3
hugger6933
There should be some foam pads under the bracing. You can buy replacements for cheap.That should fix the problem. Jim
hugger6933 is offline   Reply With Quote
Old 01-11-2016, 01:09 PM   #4
Sklptrljay
Sklptrljay's Avatar
Like these?
Old 01-11-2016, 01:13 PM   #5
Sklptrljay
Sklptrljay's Avatar
Like these?
Old 01-11-2016, 03:29 PM   #6
cdowns
cdowns's Avatar
you can wedge in torn up pieces of an old pizza box as a temp fix till you get around doin it right
Old 01-11-2016, 03:33 PM   #7
Lou Boffa
Lou Boffa's Avatar
Even with the foam inserts mine still wobbled. Finally made a simple brace that stiffened it up.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 01-11-2016, 03:39 PM   #8
PowerdbyChevy79
Cool..im going to try that out...
This is my buddys truck...
1966 C10 "Mary"
Old 01-11-2016, 09:55 PM   #9
Stu Pidd
I went to the auto parts aisle at Home Depot and bought a 1/2" x 1/2" x 36" square steel tube. Squirted some satin black paint on it, and used 3M double-sided tape for mounting chrome trim to stick it under the hood's center ridge.
Took 90% of the hood's flex away, and nobody notices it there.
Stu Pidd is offline   Reply With Quote
