Lq4 valve spring recommendations?
Just bought a Vinci ultra tourque cam for my 6.0. He recomended not using the stock springs. Was wondering if anyone had a recommendation for replacements? He has some but they are 300 and just not in the budget as the wife is not happy about the money already spent. (Chewed lifter and cam) the heads are off for new lifters so now is the time if I can find a set that's affordable.
blessed are they that expect nothing, for they shall not be dissapointed |
Re: Lq4 valve spring recommendations?
What's the specs on the cam...
1979 ![]() 1996 Silverado x-cab "the daily" |
Dur @ .004" 272*/280*
dur @ .050" 210*/218* lift .551/.551 lsa 116* 2a
Boosted Member
Put some LS6 valve springs in there. They are dirt cheap, and that cam is almost the same lift as the LS6.
http://www.summitracing.com/parts/nal-12499224
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Cool so do I need anything else or will my seats and retainers work?
Boosted Member
Retainers, locks, and valve seals should all work. Those springs are a direct replacement for stock truck springs. Don't forget to check your pushrod length with that new cam.
