Old 01-11-2016, 04:55 PM   #1
JMD
JMD's Avatar
Best seat for a short guy
I see all these posts about choosing the best seat for tall guys, but what about those of us who are vertically challenged? I'm 5'7, and I'd really like to be able to see over the steering wheel of my k20 when it's complete. Keeping the stock vinyl bench would be preferable, but is it comfortable for someone my height? What are my options? (bench/split bench seats only please, not interested in buckets) Thanks!
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 01-11-2016, 05:35 PM   #2
cypressbog
Go Pack Go!
Re: Best seat for a short guy
Amazon.com: DRIVER'S ANGLE LIFT SEAT CUSHION WITH... Amazon.com: DRIVER'S ANGLE LIFT SEAT CUSHION WITH...
cypressbog is offline   Reply With Quote
Old 01-11-2016, 06:03 PM   #3
XwalkerX
XwalkerX is offline   Reply With Quote
Old 01-11-2016, 06:41 PM   #4
68bowtie
68bowtie's Avatar
EDIT: never mind just saw you aren't interested in buckets.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
68bowtie is online now   Reply With Quote
Old 01-11-2016, 06:44 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Keep the stock seat and have it reupholstered, and ask them to add more foam. If the steering wheel ends up too close to your legs, a smaller diameter wheel will fix that.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-12-2016, 12:06 AM   #6
swamp rat
swamp rat's Avatar
If your not aware chevy came up with 2 different bench seat types, well, 4 if you include the forward folding back rest that was discontinued about 69.
On the bottom there is a spring seat and a full foam seat, the way to tell is to look under the seat, if the metal springs are arched upward running front to back its a spring seat and it has a thin foam cover of about 2-3", if the springs go straight across the bottom frame (not really springs) then its a full foam seat.
The seat foams will break down over time, the foam on a spring seat is not reproduced so ya have to find some foam at an upholstery place, foams come in different densitys so try and match the stock, its kinda a crap shoot. if you add thickness then you will have to get a custom made seat cover.
The full foam is reproduced, ether chinese junk or a USA quality full foam seat cushion from from Classic industrys, the new foam will tend to raise you up a little. They are pricy tho and you have to go thru a part supplier to buy the foam, someone like Truckseats here on the forum can get you both foam and cover, so can other suppliers.
If you don't have a full foam seat you could find one and go that route, there was a build i was reading here where a guy was happy with his old full foam seat but he replaced the foam and cover like i described above and he said it raised him too much, he was well over 6' and his head was hitting the celing.
Guess i could add, I'm 5'8' and i have no trouble with vision in my truck.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-12-2016, 12:29 AM   #7
jeffahart
jeffahart's Avatar
I'm 5'10" and the stock bench seat makes me sit up fairly high and the seat is pushed all the way back. I think a stock bench seat would be perfect for your height. Just move it up a bit. I find the sock bench to be posturepedic and comfortable.
White K20
jeffahart is offline   Reply With Quote
Old 01-13-2016, 10:10 AM   #8
I'm probably 5'9" now and when a factory seat is healthy all is good. I keep the seat all the way back, too. If it sags due to bad springs I am looking right at the steering wheel. Drives me crazy! Tilt wheel fixes that. I fit just fine between a healthy full foam seat and tilt dropped lowest. I've had extra foam added to standard seats. Those aren't reproduced and I always have those covers made at my local upholstery shop. If none of this is enough, you could space the seat off the floor. Just be sure to so it right, so it's as strong as original.
Old 01-13-2016, 12:56 PM   #9
OlSmokey
I'm 5"8 and my head almost touches the roof of the truck if i just sit up straight. I don't know, i've never had a problem with it being to low.
OlSmokey is offline   Reply With Quote
Old 01-14-2016, 09:47 AM   #10
Hey, 5'8" is gettin' tall for a gal
Old 01-14-2016, 12:33 PM   #11
Money_pit
Money_pit's Avatar
Lol the booster seat even replicates a phone book that's a good one
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 01-14-2016, 12:38 PM   #12
michael bustamante
michael bustamante's Avatar
im 5'6" (guys all braggin about bein taller than me!) my reupholstered spring bottom bench seat in my 67 is perfect for me. see right over ther steer wheel (stock) no problem
1967custom
michael bustamante is offline   Reply With Quote
Old 01-14-2016, 07:35 PM   #13
JMD
JMD's Avatar
Originally Posted by XwalkerX View Post
Oh you guys are hilarious I actually have one of these already, my friends think they're comedians.
I need new friends...
Sounds like the best option is a re-foamed original seat. LMC wants $400+ for new foam!? Yikes.
Old 01-15-2016, 12:09 AM   #14
71sierragrande
Petroleum User
71sierragrande's Avatar
I wish you and I could trade problems. Im only 5'10" and my big poofy bench seat makes me feel like I'm a seven footer, and it's all the way back to the cab wall. Still no legroom at all. Mine is a reupholstered stock bench, the PO may have had extra foam added when it was redone.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 01-15-2016, 10:02 AM   #15
Grumpy old man
Grumpy old man's Avatar
Go to your local auto upholstery shop and let them custom build the foam so it fits you just right and then you'll be happier driving it .
Grumpy old man is offline   Reply With Quote
Old 01-15-2016, 11:04 AM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
x2 - when my '69 had a bench in it, it was a spring bottom seat with fairly new foam. I had no problems. The stock seat does actually sit up high like a 'truck' - go figure...
I have scat 'pro car' buckets in the truck now and actually had to lower the seat about 2.5" because I couldn't get my legs under the steering wheel, and it's a smaller than stock steering wheel (15").
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-15-2016, 01:19 PM   #17
kehstr
kehstr's Avatar
try being 6'1" it's even worse
kehstr is offline   Reply With Quote
