Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-11-2016, 08:47 PM   #1
cheap
Rear coilovers
Anyone running rear coilovers, specifically on a 73-87 1/2 ton? I was curious what spring rate you were running and shock length.
cheap is offline   Reply With Quote
Old 01-11-2016, 09:45 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Rear coilovers
You can use the replies as a loose guideline, but there are so many factors involved that affect the shock and spring selection (e.g., how the shocks are mounted, etc.) for an individual vehicle. The best advice I can give is for you to scale your truck (with you and all of your racing and safety equipment, etc.), and use one of the racing suspension formulas for the type of racing you'll be doing.
Here are some links to help get things started:
https://www.qa1.net/technical-suppor...ring-rate-tech
https://www.cachassisworks.com/Attac...1-226_drag.pdf
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-12-2016, 12:36 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Rear coilovers
x2
Only thing I can add is that you probably won't have the right rate the first time, and you might end up wanting a few sets of springs if you ever do truck stuff with her. At least on a bridged setup, its really ends to pop the springs off and go from daily to track setups.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
