Old 01-11-2016, 08:47 PM   #1
Scott5
Air bag
I'm wanting to put air bags in the front of my 69. I want to leave the stock upper and lower a arms. Do I need to do anything to the arms to accept the bags? Like cut or weld anything to them? Thanks
Scott5 is offline   Reply With Quote
Old 01-11-2016, 08:50 PM   #2
72MARIO
72MARIO's Avatar
Re: Air bag
Everything can be bolted on. Drill 10 holes up front and 6 out back
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-12-2016, 02:48 AM   #3
BigMike
BigMike's Avatar
Re: Air bag
You just have to drill the holes for the upper bag plate, the bottom of the bag will bolt onto a cup that sits where the springs used to. The lower cup doesn't get welded or bolted to the lower arm. You'll also need to drill holes it the upper spring pocket to run the airlines.
If you look at my build, I just finished installing bags so you can get an idea
BigMike is offline   Reply With Quote
Old 01-12-2016, 02:51 AM   #4
Scott5
Does the cup come with bags? Or is something else I need to get?
Old 01-12-2016, 02:56 AM   #5
BigMike
BigMike's Avatar
Re: Air bag
Some do, most don't. Basically you just look for a 63-87 bag brackets. http://www.azproperformance.com/63-8...-Brackets.html
Call Travis at AzProPerformance.com & tell him you're a member & he'll hook you up pretty good with whatever you need. he is also extremely knowledgeable about our trucks & will point you in the right direction.
I bought my Accuair E-level setup from him and he made sure I have everything I needed for the job.
Old 01-12-2016, 02:58 AM   #6
Scott5
Some do, most don't. Basically you just look for a 63-87 bag brackets.http://www.azproperformance.com/63-8...-Brackets.html
Old 01-12-2016, 02:59 AM   #7
BigMike
BigMike's Avatar
Re: Air bag
No worries. Also, he ships super fast so you'l get them right away.
