Old 09-20-2003, 12:08 AM   #1
Injected68LS1
Injected68LS1's Avatar
Smaller Power Booster retrofit --> Anyone done this?
I'm going to try to find a smaller power brake booster to replace my old one. I would like to use a 7" one but I don't know if they work well. Anyone tried this?
After I did that I was going to try to get a newer car master cylinder to fit. I like the look of the aluminum body with the plastic reservoir. Any thoughts on a direct fit?
Any thoughts would be great.
Injected68LS1
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 09-20-2003, 12:31 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I think that stainless steel brakes make's a kit for that ???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 12:35 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Here is some thing similar to what you want correct,just with the newer master cyclinder correct???
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 12:41 AM   #4
c-10 racer
Your long lost cousin
c-10 racer's Avatar
have you got front disc? I think it's gonna be hard to use a newer aluminum master if you don't.....
93 K1500 Ext. Cab
c-10 racer is offline   Reply With Quote
Old 09-20-2003, 01:36 AM   #5
Injected68LS1
FRENCHBLUE72, Yeah. That's what I have in mind. Except for the newer style master. Is that yours? Any idea if the smaller booster still works strong?
c-10 racer, I will be converting to Baer F/R discs. I believe it should work just fine. I'm sure I'll have to find some newer style prop. valve too.
Old 09-20-2003, 01:51 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Nope not mine sure would be kool though.. M y guess is if it slow's down this motor it should slow down a street truck.. Also you can get wilwood proportioning valve's that are adjustable threw summit...
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 11:12 AM   #7
Bowtiefreak
Bowtiefreak's Avatar
I don't have one on my truck but I ran the master power unit in my bigblock camaro and it worked like a charm. I plan on using one in the truck too. btw,I did use a standard cast master cylinder, not a newer plastic one.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 09-20-2003, 08:57 PM   #8
Injected68LS1
I checked out master power and it seems they know all about brakes. I think I will go with 8" dual diaphram booster and a disc/disc combination valve. I'm still on the search for a newer style master cylinder.
Old 09-20-2003, 09:55 PM   #9
dinnut
dinnut's Avatar
i got a cool looking master
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-21-2003, 07:25 PM   #10
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Slammed67 has a newer aluminum Master
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 09-21-2003, 08:31 PM   #11
mikeoj
check out booster setup from a s10
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 09-21-2003, 10:39 PM   #12
Injected68LS1
Did the S10s come with front and rear disc brakes?
Old 09-21-2003, 11:41 PM   #13
mcmlxix
Collector of Projects
mcmlxix's Avatar
Newer Astro vans have 4 wheel discs, so do the full sise vans and Tahoes. Maybe even Silverado .. but most likely have ABS .. dont know of that would make a difference....
I want to change my setup too. The stock power booster sticks out so far into the engine bay ... I think I would like it flush against the fire wall ... and the smaller booster too would be nice.
Rich
1972 K5 Blazer CST Click HERE
Old 09-22-2003, 12:03 AM   #14
Injected68LS1
Thanks for the info. I have a brake application guide at work. So I'll be able to look up the part numbers and piston diameters.
Not sure if it is wise to put the booster right on the firewall. I think that you would have to get rid of the lever between the pedal and the booster. Then to center the booster with the rod you would have to modify the whole pedal assembly and mount. I'll have to look at it closer to see if it's possible. If it isn't, then we're stuck with the booster sticking out a ways.
