Old 01-12-2016, 12:01 AM   #1
74baggedbug
AAW crimper
Does anyone have the American autowire crimper they would like to rent out.. Figured I'd ask before ordering it and using it only once
74baggedbug is offline   Reply With Quote
Old 01-12-2016, 12:21 AM   #2
jeffahart
jeffahart's Avatar
Re: AAW crimper
if you don't want to buy one, you can use your cheap crimper and solder. I used the proper crimper but I did a fair amount of soldering too, as I recall. Also, have a lot of heat shrink wrap on hand as well.
White K20
jeffahart is offline   Reply With Quote
Old 01-12-2016, 12:44 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: AAW crimper
Agree 100%! I have always soldered everything, and have never had a bad connection. Best way to go imho.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-12-2016, 11:00 AM   #4
cooperhw
cooperhw's Avatar
Re: AAW crimper
^^^Agree^^^ I take regular wire ends and pull the plastic covers off. Crimp em on the wire with small wire cutters (carefully) then solder every joint. Real trick I found is to buy a small fly tying base from harbor freight. It has a small base with two alligator clips pointing up. I clip the wire in and use that to hold both ends while I solder. frees up my hand to hold my small torch and one to hold the solder.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-12-2016, 11:08 AM   #5
BrianG
BrianG's Avatar
Re: AAW crimper
This is the kit that I am using to do my AAW kit:
S & G Tool Aid 18920 Ratcheting Terminal... S & G Tool Aid 18920 Ratcheting Terminal...There are dozens of kits that are similar to this that I'm sure would work also. Some have more or less dies for doing different ends. I've used only one or two of the dies. I also ended up buying another die to crimp spark plug wire ends and that worked really well. The kit that I mentioned above will do probably 95% or more of the crimps that you'll need to do and you'll get a very professional looking crimp on them as well. I think the only ones that I've had a little trouble with are the ones where you have to join two wires together. Some have worked fine, but some (especially the really large wires for things like the headlights) gave me a little bit of trouble trying to crimp just right. I also soldered most of my connections. Not that I would have had to, but I thought, why not. It is easier to do it now then try to find it later and do it.
BrianG is offline   Reply With Quote
Old 01-12-2016, 02:31 PM   #6
tim's68gmc
tim's68gmc's Avatar
Re: AAW crimper
S & G Tool Aid 18920 Ratcheting Terminal Crimping Kit- 5 Piece - Crimpers - Amazon.com
I am using same crimper and they work great
vehicle's I own 1968 gmc 3/4 ton camper special
1972 gmc jimmy
1972 Chevrolet nova
1947 ford 1.5 ton dully
1997 f-350 1 ton
2007 Chrysler 300 with hemi
tim's68gmc is offline   Reply With Quote
Old 01-12-2016, 02:54 PM   #7
davepl
davepl's Avatar
Re: AAW crimper
I was at my local old-guy shop a couple of days ago and he was sorting through BOXES of different types of terminal kits trying to find something for a weird harness, but I thought I was a big man with a Packard terminal release tool and a flat screwdriver. He must have had 30-40 different ones right there.
Same with crimping... you mean there's more than three styles and sizes?
I feel like Marge looking at a 8-slot spicerack: "There must be duplicates".
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-12-2016, 06:20 PM   #8
bill3rail
bill3rail's Avatar
Re: AAW crimper
Crimping is good, but corrosion can still get in there so soldering is MORE important!
Make sure you get a good hot soldering iron first!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 01-12-2016, 08:34 PM   #9
Orange Crate
Orange Crate's Avatar
Re: AAW crimper
I also bought the Tool Aid 18920 crimper and it works great. There are a couple of crimps that require a double wire crimp, like at your headlight connectors. This is where two wires lay next to each other in the same terminal. There is a "double wire" crimper or a "two wire" crimper but it isn't really necessary. You can crimp these by using a pair of needle nose pliers and then solder the terminal when you are done. I would recommend soldering these terminals because of the current draw required to run your head lights plus it does add security if your crimp with the needle nose pliers isn't maybe the best. Take your time and curl the terminal "tabs" over the two wires and you'll be just fine. I just finished my AAW kit and there are only a few places that have a double crimp.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
Orange Crate is offline   Reply With Quote
Old 01-12-2016, 09:59 PM   #10
redbaron
redbaron's Avatar
Re: AAW crimper
American Autowire has a rental program for the them. We own the tools and they work great.
The Link: http://www.americanautowire.com/prod...rimping-tools/
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
Old 01-12-2016, 10:59 PM   #11
Longhornss
Re: AAW crimper
Rent the proper tools from AAW when you get your harness. They give you practice "kits" in each harness they sell, so you can get a feel for how each different terminal crimps. Soldering is ok but if you have the proper crimp it is not required. I rave heard techs both from AAW and painless recommend not soldering due to overheating the copper can cause it to become brittle or the flux in the solder can cause premature corrosion of the wire.
Don't flame me that is what I have been told by the guys building the harnesses.
Longhornss is offline   Reply With Quote
