best year nonvortec 350?
65 SB stepside
Nonsyncro muncie(will change to synchronized) 3.73 rear Would like a283-327 but seems 350 may be easier/cheaper to find Is there a"best" year to get said 350? |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: best year nonvortec 350?
Are you looking for an engine to build or just a used engine to install and drive? What don't you like about the Vortec 350?
Yes just one to buy in or out of a truck
Do minor rebuild and install Nothing about vortex but seems more complicated fuel and some say they prefer tbi to vortec I want just a baseline motor that I can upgrade as wanted and F.I. Isn't what I want to deal with just yet..(very familiar w/VW-Porsche F.I.) Simple carb simple exhaust no extra nothing |
![]() Join Date: Jan 2011
Well any of the roller cam one piece rear main engines would be my pick. The first vortec engines were the 95 to 2000 small blocks with the vortec heads. That is what is in my truck. These are non LS engines and make good reliable engines. The intake is specific to the heads but still easy to get.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
The Vortec L31 engine is still a Gen1 SBC.You can run a carb on it,or,EFI.It does need a Vortec specific intake.It's a really good engine.1 piece rear seal,roller cam/lifter setup.These motors are rated at 255 HP,but,that is the net rating as installed in a factory vehicle with factory exhaust,tuning,etc.With a good intake,4 bbl carb,& decent exhaust,these engines will hit 300 HP without breaking a sweat with the stock longblock.Add a small performance cam & 350 HP is a cinch.
You will need a flywheel for an 87 up 1 piece rear seal motor.You will also need to use an electric fuel pump because there are no provisions for a mechanical. My 97 has 610,000 miles on it.The original motor was pulled at 248,000 mostly due to low idle oil psi.Motor was still in good shape.When torn down,there was still visible crosshatch & no ring ridge at all.It's in the process of being rebuilt now.I replaced it with a Goodwrench crate L31.(Which,by the way,you can buy a brand new L31 for less than $2000.New complete long block with oil pan,timing cover,& valve covers,not rebuilt.)That motor now has over 360,000 miles on it & still going strong.The EFI & 4 speed auto are a big contributer to that as well. Last edited by jokerz71; 01-12-2016 at 09:03 AM. |
#6 | |
#7 | |
60-66 Nut
I see no reason to not use a '96-'02 L31 Vortec engine. You get a one piece rear main seal, the factory roller cam and a set of the best production heads GM produced for a small block. Just drop a carb and intake on it with a regular HEI and you'll have a great engine. You'll need to be sure to change the distributor gear to one that is compatible with the factory roller cam. The only drawback I can see to building a L31 Vortec, is that you'll have to run an electric fuel pump. But that really isn't a big deal breaker IMO.
Captain, Will the Vortec intake take a Quadrajet, or is there an adaptor needed?
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
Post Whore
![]() Join Date: Mar 2013
An early 70's 350 would be the "best" version I guess. Any year before the smog version would get you the best power. You can get a crate motor for a pretty darn good deal though. If you come across a 327 I'd pick it up if it runs good. It's still a SBC so they are pretty much all cheap to build or fix up.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#12 | |
For less than $2000,you get a brand new(not rebuilt) motor with a 100,000 mile warranty,roller cam/lifter setup,the most powerful efficient head GM has ever produced on an OEM vehicle.You would be hard pressed to even do a complete rebuild on a motor for much less than that. It is still a Gen1 small block,so,anything that will bolt to previous years will bolt up & work on the L31,except for the intake & flywheel.If,you have a pre 86 motor,you will need a flywheel for a 1 piece rear seal motor. |
#13 | |
Post Whore
#14 |
Sorry.I meant no harm,or,disrespect.I just said I disagree that an early 70's 350 would be the "best choice".If trying to stay period correct,then maybe so,but,not as far as the best motor overall.
#15 |
though the best 350 came out of a 67 corvette or camaro.. based on power that is..
#16 | |
The 96/2000 350 Vortec has a net HP rating of 255 HP as installed in an OEM vehicle with stock factory exhaust,emmissions equip,& factory pcm tuning.You can take that same motor & put a 4 bbl carb/intake & headers & make an easy 300 HP.The heads on this motor offer an automatic 30HP,just by bolting them on to a motor without any other changes & that's comparing them to something like Humps.Compare them to a smog head & it's more like 40 to 50 HP. That's not mentioning the benefits of the 1 piece rear seal & roller cam/lifter setup. |
#17 |
#18 | |
*** That's interesting ***
Short water pump bolts right up. Can't think of anything besides the flywheel, distributor, and fuel pump that would need changed either. Electric fuel pump is easy and safe if you run it through an oil pressure switch. So my vote is also L31. With carb intake and HEI (if you want old school). By a large margin.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#19 | |
1973 C20, 350/350 |
#20 |
![]() Join Date: Feb 2007
...not to mention adding a retro-fit roller cam to a non-roller small block is a $900-1000 upgrade. That's half the cost of an L31.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#21 | |
Every once in a while someone mentions the need for a coolant bypass with the vortec. Is it not cast into the block like all the other SBC's?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#22 |
An old style cover will work,but,requires that you silicone a couple of places as the new cover uses 2 less bolts.The block does not have the bypass cast in.The hole is there in some blocks,but,it is not open thru.Plumbing an external bypass is no big deal.
#23 |
I went through this when I rebuilt my 350. I bought up into the hype and rebuilt a Vortec 350. Great engine but I can't stand the electric fuel pump. It's expensive, loud, needs a regulator and is a pain in the ass to set up. They also require a more expensive intake. For those reasons if I could due again I would try to find a TBI block 87-95? set up for a roller cam and mechanical fuel pump.
#24 | |
#25 |
I am using a blue holly fuel pump, maybe I'll sell it and try that pump. Yes they are rare but they are out there. I searched the junkyards for a month and found a TBI 4 bolt main with the fuel hole drilled. I pulled it but couldn't use it because the block was cracked so I went with a vortec instead.
