Old 01-12-2016, 01:38 PM   #1
tommy217xxx
tommy217xxx's Avatar
Steering column question
Hey everyone, I have a tilt column out of a 77 and I want to put it in my 76. I need to replace a seal on the intermediate shaft. Ive already removed the clip but I can't figure out how to get the seal out.
Also does anyone have a part number for this seal?
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 01-12-2016, 06:25 PM   #2
tommy217xxx
Re: Steering column question
Any one got a link. I tried to find with the search feature and no luck.
TJ
80 Chevy c10 lwb
305/350
Old 01-12-2016, 09:25 PM   #3
tommy217xxx
Mines already torn. That's why I'm taking it apart.
TJ
80 Chevy c10 lwb
305/350
Old 01-12-2016, 09:55 PM   #4
hatzie
Moderator
hatzie's Avatar
Originally Posted by Chaplain View Post
If I had to do it over I would go the Jeep XJ route.
I did one in my 76. No looking back. Just do away with the original shaft entirely. Far tighter than the new rag joint on my CUCV.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-12-2016, 10:22 PM   #5
hatzie
Moderator
hatzie's Avatar
His opinion trumps mine all day any day.
Other than the Doghead starter relay mod I've tried to keep the M1008 original. For some reason the unmolested CUCVs seem to be desirable. Otherwise She would have an XJ shaft and an SM465 with a Gear Vendors OD and gauges.
The new rag joint tightened up some of the slop on my CUCV but not as much as the XJ shaft in my 1976.
Old 01-13-2016, 12:58 AM   #6
tommy217xxx
The link with the disassembled lower worked out. I found that by putting a straight slot screw driver in the slots in the ends and working each side down little by little. I actually have 2 columns. One with a good boot and one with a bad one. I need the top on the one with the bad boot on it. So I just swap tops and install the new tilt column. I would like to fine a seal but it sounds like there pretty hard to find. I read some where that early chevelles used the same column. So I'm gonna dig a little. I stopped by a Chevy dealer and there parts computer goes back to 82. Any one know if they used the same boot/column in 82?
TJ
80 Chevy c10 lwb
305/350
Old 01-13-2016, 08:47 AM   #7
hatzie
Moderator
hatzie's Avatar
Download the 73-78 & 79-84 truck parts books...
I believe Ian Harding has the Chevelle parts books on gmpartswiki.com
Old 01-13-2016, 10:08 AM   #8
tommy217xxx
I just stopped at the dealer and they said it was discontinued for like 10 years.
TJ
80 Chevy c10 lwb
305/350
Old 01-13-2016, 11:09 AM   #9
tommy217xxx
I would go the jeep route if I didn't already have another shaft and boot. I'm just gonna swap the caps and call it good.
TJ
80 Chevy c10 lwb
305/350
Old 01-13-2016, 02:37 PM   #10
slotard
I ought to go with an XJ shaft on mine, guess I should find one in a junkyard and hope it still has what I need. My steering isn't great.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-13-2016, 05:31 PM   #11
hatzie
Moderator
hatzie's Avatar
Go to Car-Part.com and look up Jeep Cherokee 1984-2001 (XJ chassis)... The part you're looking for is the "steering coupler".
Borgeson sells raw steering shaft parts to roll your own... telescoping steering shafts and single row needle steering universals. They're kinda spensive tho...
Old 01-14-2016, 12:49 AM   #12
tommy217xxx
I just took the good boot apart and it came apart a little differently. I oiled the boot all the way around where it sits in the coupler just I didn't rip it. Then I used the shaft like a slide hammer. A few little slides and it came right out.
TJ
80 Chevy c10 lwb
305/350
