Old 01-12-2016, 06:52 PM   #1
87Skier
87Skier's Avatar
Heater/Defrost vent pipes
I built a custom center console and am looking for something like the original heater vent pipes (like the ones to the defrost or A/C) that I can reroute the bottom of the heat outlet to my new vents.
I built an end cap on the original outlet to adapter to 4 1" hoses. What do you guys recommend? The closest I can find is pool/spa flexible pvc pipe.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-12-2016, 07:41 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heater/Defrost vent pipes
Google search is your friend!
http://www.ducting.com/hose-types/rubber-hose/
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-13-2016, 09:23 AM   #3
snipescastle2
snipescastle2's Avatar
Check with your local boat/marine supply place, ask for "Bilge blower hose" it comes in various diameters/lengths.....cheaper than the factory cloth covered stuff...
Ben
http://www.cpperformance.com/p-58-3-...vent-hose.aspx
snipescastle2 is offline   Reply With Quote
Old 01-23-2016, 12:22 AM   #4
87Skier
87Skier's Avatar
I have found a lot of stuff, but I can't really justify spending $40 on 5 feet of cheap hose, so I'll probably go with some plastic marine hosing.
