09-20-2003, 12:28 AM | #1 |
Driver's door won't fully close.
Hi.
I am looking at a truck and the driver's door doesn't fully close. I looked at the striker plate and it looked like it was adjusted all the way in. The door does latch, it just stays open about an inch or so. Any ideas? Is this adjustable? Thanks,
Ripley Bryant Salem, Oregon '77 Chevrolet Silverado 20 - 454 BB, TH400, Factory wood floor longbed '75 Fiat X1/9 - my AutoXer '77 Fiat X1/9 - her AutoXer '81 Fiat 2000 Spider - under construction '00 Dodge Neon - Commuter '00 Dodge Grand Caravan - Family bus |
09-20-2003, 12:49 AM | #2 |
PROJECT 7DEUCE
Had to go out and look at the latch and it appear's that the door latch with the tumbler in it click's twice sound's like your is only clicking once??? Could be wrong but I think you need a new door latch let ... If some one also point's this out I may have a spare latch...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-20-2003, 12:52 AM | #3 |
KEEP ON TRUCKING
check and see if its got new rubber seal sometimes the repos arent right and will cause this
72 cheyenne 2wd lwb 71 k20 sons bassett va |
09-20-2003, 12:57 AM | #4 |
Thanks. I'll look at the seal and the latch.
If I remember correctly, I could push the door flush with the cab, but it didn't stay, it would just pop out an inch or so, so it may be the latch.
