01-12-2016, 07:14 PM | #1 |
Cpp control arms for a airbag
Hey folks I am think about ditching my cupped control arms on 72 for a set of cpp arms so I was wondering if anyone had a picture of the control arms for airbags cause all they could tell me is that it has provisions for the ride tech mounting brackets so I don't know if these will work with my DOM 2600 bag. And another thing before I make the purchase are they really worth the money cause I've heard that it will get the front a little bit lower.
01-12-2016, 08:11 PM | #2 |
67-72 parts collector,…
Re: Cpp control arms for a airbag
I remember old threads about CPP a-arms for bags having a small area to mount the bag. Meaning,... you would have to run a 2500 bag up front to keep from rubbing the sides of the bag on the a-arm.
In my opinion there are better a-arms. Porterbuilt or Ridetech would be my first choice. No a-arm is going to get you lower than the cross shaft that is bolted to the crossmember. This is the lowest point on these trucks. You need to get a sectioned crossmember, z'd frame, or aftermarket crossmember like the Porterbuilt Dropmember, to get your suspension higher in the frame rails, to get the front lower to the ground.
01-12-2016, 08:57 PM | #3 |
Thanks lolife99 I'll look into Porterbuilt
01-13-2016, 02:56 AM | #4 |
Yeah i could get arms made just for bags you will be happier in the end.
01-13-2016, 07:58 AM | #5 |
Diggin The SquareLife
Also there is mmw that makes arms thats what i have for my truck
01-13-2016, 09:41 AM | #6 |
01-14-2016, 02:39 AM | #7 |
He has these for the 73-87 http://michiganmetalworks.com/store/...product_id=120 they should work on a 72 back
01-14-2016, 12:37 PM | #8 | |
