Heater feed Help Needed
Hey everyone - I am learning to do a lot of the work myself on my truck and other cars but somethings I haven't done just yet - the heater being one. My 64 looks to have the deluxe heater box from what I have seen posted in the FAQ area but is currently not connected. I need some help figuring out where the feeder hoses connect to on the block since the engine is not original to the truck (chevy 350). If this has been discussed before sorry I did search.
Took a few pics for reference on what I mean This picture shows the heater box to the left with the 2 ports circled - my question is where do I run hoses too? Am I correct with what I circled over on the engine? Thanks for the help ![]() Here is another angle ![]() Thanks for any help as always |
Re: Heater feed Help Needed
The hose closest to the box (should be 5/8ths) goes to the manifold
The hose closest to the fender (should be 3/4ths) goes to the water pump. i'll post a pic in a minute
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
You may want to make sure the heater core is not leaking. That may be why it was not hooked up.
If you don't like this ![]() |
![]() Join Date: Aug 2009
Who knows how old it is as with my recently purchased 64 I'm going to replace mine while I have the engine out.
i picked up mine from O'reilly's for about 35 bucks. not terribly expensive, but any aftermarket cores will be aluminum. Bear that in mind.
use an MHT 94788. http://www.oreillyauto.com/site/c/de...&keyword=94788
man i love this forum! I needed this exact information as well and here it is, just waiting for me. thanks guys.
I have what looks like the same heater box, how do I know if it's the "deluxe" and what does that even mean?
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
There are three different models (four if you consider a delete option)
this thread covers alot of the info regarding the heaters offered for these trucks http://67-72chevytrucks.com/vboard/s...d.php?t=488618
Looks like you have the deluxe heater and not the recirculating. I may still have a good original copper heater core for the deluxe. I can look if you're unsure about your core.
#13 |
#14 | |
#15 |
I took my heater core to a rad. shop and had it cooked and pressure tested, came out it was ok, cost $25.00 bucks, and I am sure it is a lot better quality than what you can buy now days.
#16 |
Just pulled mine out tonight - looked like original copper from what I can tell. Going to order a new one unless someone has one.
#17 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Measure your heater core once you have it out. There are 2 heater cores that look the same but are different lengths. The Deluxe heater will be the largest and the Economy heater is a little smaller.
#18 |
Thanks for this Capt - from my reading both will work is that correct? Anyone know which Oreilly sells?
#19 |
That MHT I linked is the same size as the economy, but it puts out a good amount of heat. remember, it's aluminum
#20 |
60-66 Nut
If you have a Deluxe heater and install an Economy heater core, you will have to block off part of the larger hole that is for the Deluxe heater core.
#21 |
![]() ![]() Join Date: Jul 2002
Here is the two cores in a deluxe heater. As the Capt' said, they both fit, but the economy core is much shorter and you'll need to block it off so you will actually get some heat.
#22 |
#23 |
I got mine from LMC
#24 |
60-66 Nut
You should be able to get one from your local auto parts store.....I did. There are some part numbers in the thread "All about heaters" The part numbers will vary between brands.
#25 |
