Old 09-20-2003, 12:36 AM   #1
newsalem2004
welders
I was wondering what kind of welders you guys use for your body work. I have a Lincoln pro 100. Also what mixtures of carbon dioxide and argon you use for shielding gas. thanks
newsalem2004 is offline   Reply With Quote
Old 09-20-2003, 12:44 AM   #2
walker
walker's Avatar
I use a millermatic 185. I like the blended gas argon/co2/helium I think. Praxair calls it Stargon. It seems a lot cleaner to me than the co2. Just remember, small welds. A thousand little spot welds spaced apart beats the pants off of alot fewer 3/4" long welds, as far as minimizing warpage.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 09-20-2003, 12:50 AM   #3
J.Lance
Too many is never enough!
welder
Ditto on the Millermatic 185 and the gas. Very good all around welder. You can do everything from spring perches to cab corners.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 09-20-2003, 12:57 AM   #4
Richard
I got a Millermatic 175 for my b-day a few months back with the cart, auto dimming helmet and an 80lb cylinder. I am using the C25 mix, 25% co2 and 75% argon at about 12/15 psi. After a little practice I find it easy to make excelent welds. I have used the Lincoln 100 at work with flux core wire and was very frustrated. I dont know if the 175 is a great welder but it is a dream to use compared to the 115v 100 amp. Was well worth the trouble of installing the 230v circuit IMHO.
Richard
Richard is online now   Reply With Quote
Old 09-20-2003, 09:04 AM   #5
I have a Lincoln SPT100 and so far it's working out real good for me. Using a CO2/Argon (25/75...I think that pretty much Industry standard). I don't do a lot of welding and it is mostly sheet metal so the 110 welder not a problem at this time. I'm sure I'll get a bigger one down the line as I start doing this stuff more.
Old 09-20-2003, 11:08 AM   #6
mrein3
mrein3's Avatar
My Millermatic 175 is one week old today. I bought the 25/75 CO2/Argon mix, wired a 220v outlet, and completed my first project last night.
Best tool I've bought in a LONG time.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
