![]() Join Date: Sep 2015
Inline 6 Accessory drive brackets
I am adding power steering and eventually A/C to my '71 Inline 6 250, so I started looking for triple drive bracket setups. Here's the one I just ordered:
![]() I think it will work well for me, I'm going to have a new HEI, Alternator with internal regulator and a Clifford 6=8 Intake. This bracket setup will clear them all. Need to add a two groove water pump pulley and add a single groove pulley to the existing 2 groove crank pulley, but those are easily available.
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline |
Re: Inline 6 Accessory drive brackets
FYI: They also have the Power Steering bracket by its self:
![]() Join Date: Feb 2002
You could also try the GM 3-Groove 292 Harmonic Balancer, p/n:10141202.
A 292 Balancer on a 250 would be fine [but a 250 Balancer on the larger L6 wouldn't have enough mass to be effective.] Nice looking L6.
Where did you order it from?
Hope this isn't against any rules. I ordered mine from http://ecihotrodbrakes.com/chevrolet...ve_system.html
I see that the picture above is from ECI's web page.
Do they give you an application for a upper radiator hose that works with the water outlet pointing straight forward? I would be nice if they showed other views of their brackets. I wonder if the brackets have triangulated bracing or did they rely strictly on that annoying crossbar?
'67 GMC 2500, 292, 4spd, AC |
Cross bar doesn't bother me. Your other question , do you mean like an Inglese Cool-Flex hose ??
This picture was posted here about seven years ago.
You want to use a hose like this in a big "S" shape and obviously with an electric fan?
Exactly. That is the CoolFlex Inglese I mentioned.
#10 | |
http://www.67-72chevytrucks.com/vboa...=265005&page=2
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-14-2016 at 09:04 PM. |
It looks like there may be other problems with pritch's setup.
As it sits, the Alt belt is not making near enough contact with the water pump pulley to keep the water pump from slipping. The Alt belt is on the front groove of the water pump and the rear groove of the crank pulley. The extended thermostat housing is going to interfere with any belt for the AC compressor no matter what. ![]()
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 01-15-2016 at 01:49 AM. |
My understanding is the dual groove water pump pulley drives the Alternator and the A/C compressor, and I have a single groove pulley to ADD to the from of the Crank pulley/balancer which drives the power steering pump alone.
The A/C compressor side is adjustable outward to allow clearance of an HEI Distributor. I see what you are saying about the Alternator belt, Once I recieve mine I'll try to post up here on successes or shortfalls.
#13 |
I have have some olders 'Zoops' adjustable brackets on my '34 which allow some outerward adjustment on the bottom of the Alternator. Might look at those too.
| Bookmarks |
