Old 01-13-2016, 11:27 AM   #1
greywurm
350 SBC Motor Mount Bolts - Which are correct?
I lost a bolt for my driver side motor mount yesterday, the center bolt of stand to mount, and the passenger side is loose (might have loosened on the 5 minute return trip home).
I have done some researching and it looks like I might have been using the incorrect bolts, but I am not sure how I would get a nut on the bolt between the mount and the engine block.... it was hard enough lining up the engine to the stand to get the center bolts lined up!
Anyways, I attached the pic of the bolt I used from the 250 I6 I pulled and these ARP bolts from summit.
Would the lack of a nut on the opposite side contribute to the bolts loosening and coming out?
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline   Reply With Quote
Old 01-13-2016, 02:08 PM   #2
greywurm
Re: 350 SBC Motor Mount Bolts - Which are correct?
I know... Probably a stupid question...
Old 01-13-2016, 02:56 PM   #3
michael bustamante
michael bustamante's Avatar
no the v8 motor mounts should have a nut tacked onto them. most guys use a locktite on the bolts
those new ones look like they would be for the clamshells like on a 73 and newer half ton
1967custom
michael bustamante is offline   Reply With Quote
Old 01-13-2016, 03:42 PM   #4
greywurm
All I have been able to find so far are those ARP branded bolts or something just like it. I hate asking for someone to find a part, but I really dont know what to look for or what im searching wrong. That is what came up for my 71 year truck on summit and the local shops' sites.
Old 01-13-2016, 06:00 PM   #5
67c10rustbuket
67c10rustbuket's Avatar
7/16 --14 x 1 1/4" long.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-13-2016, 06:02 PM   #6
67c10rustbuket
The "NUT" is molded inside the rubber mount.
Dan <---(my name)
Old 01-13-2016, 06:05 PM   #7
michael bustamante
I bet i have a pair. ill look and let you know in the morning
1967custom
Old 01-13-2016, 06:21 PM   #8
greywurm
There is a nut in the mount, so I guess my issue really was just that I didn't use thread locker on the bolt.
What do you suggest, red or blue?
Old 01-13-2016, 07:06 PM   #9
michael bustamante
well youll never really have to take it back out until the motor mount or the motor itself fails so whichever is stronger
1967custom
Old 01-13-2016, 07:07 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've never used Loctite on those bolts. Never lost one.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-13-2016, 08:03 PM   #11
greywurm
Gary
For what its worth, the one that came out looks like it could use a new lock washer.
Old 01-13-2016, 09:03 PM   #12
67c10rustbuket
Gary
Ditto.
They are a pita to get to on the original mounts. I bet someone tightened it the best they could (not fully tightened) and it vibrated loose. I recall flipping my ratchet back and forth 100 times an 1/8 turn at a time then thinking I should have changed to the later clamshell style.
Dan <---(my name)
