Old 01-13-2016, 05:02 PM   #1
Wrenchbender Ret
292 carb.
I have a carburetor from an 81 292 engine. It has the electric choke so it can be used on any manifold without divorced coil & linkage. The vacuum pulloff works & the heater coil works. as does the idle selinoid. It should have a kit put in before use as it has been setting for a long time. This carb has a larger bore & venturi then the 250. It has no rust or corrosion. $50 plus $15 shipping.
George
SOLD
Wrenchbender Ret is offline   Reply With Quote
Old 01-19-2016, 10:17 AM   #2
daveklein
Re: 292 carb.
I sent you a PM.....Dave
daveklein is offline   Reply With Quote
Old 01-19-2016, 04:50 PM   #3
Wrenchbender Ret
Re: 292 carb.
I replied.
George
Old 01-19-2016, 09:45 PM   #4
RickDeVon
RickDeVon's Avatar
Re: 292 carb.
Can I replace my stock carb on my 250 with this???
71 C10 I6 250 TH350 power steering and power breaks...
RickDeVon is offline   Reply With Quote
Old 01-19-2016, 11:26 PM   #5
Wrenchbender Ret
Re: 292 carb.
It will fit good but I'm not sure how it will run. It has larger throat & venturies then the 250. Dave has first pick at it.
George
