Old 01-13-2016, 05:40 PM   #1
1774btcrew
1774btcrew's Avatar
Crappy Dorman 49300 turn singnal cams. Any alternatives?
Let me start off by saying I am well versed at building steering columns. All of the columns I rebuild get new turn signal cams as they most often are brittle and split where the lever screws in. As of recently, the quality of the Dorman ones has went WAY down. They no longer cancel when using the left hand turn signal. The right side works fine. I have also found the retaining clips on the regular OEM turn signal only catch the lip of the cam on one side. This isn't critical but me being a perfectionist, it really bothers me. For some reason Dorman must have changed there molds. I have also tried different turn signal canceling cams in hopes they would work with Dorman's turn signal cam to no avail. I am at a loss! The only other alternative, is a complete turn signal switch. This is really too expensive to put in these columns for what I charge AND you can't get the correct lower plug for the 73-74 trucks. This annoys me as well. I now you can get an adapter harness but that isn't the cleanest way to go. That leaves me with having to unpin the newer plug and install the earlier plug. That isn't even that big of issue if I am doing an exchange for a customer but if not, I have to scramble to find a 73-74 plug. I just don't understand why Dorman cannot build the cams right. Are there any other alternatives?
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-15-2016, 04:37 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Crappy Dorman 49300 turn singnal cams. Any alternatives?
No one has any input or experience with these at all?
Old 01-15-2016, 06:41 PM   #3
83GMCK2500
Looks like year one has some, not sure quality, but they seem affordable. LINK
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-15-2016, 07:25 PM   #4
1774btcrew
1774btcrew's Avatar
Thanks for the link. I called them and they were already closed so I sent them an email asking for information making sure that they are NOT the Dorman brand. We will see what they have to say. I am at a loss and hate to think that I would have to stop rebuilding steering columns due to being unable to get quality parts
Old 01-15-2016, 07:29 PM   #5
1774btcrew
1774btcrew's Avatar
I have checked and their shipping is excessive at almost the same cost as the items. I checked on getting 10 of them and the parts total was $69 and shipping was $38. Just sucks since they don't weigh anything to speak of
Old 02-17-2016, 01:15 AM   #6
tommy217xxx
tommy217xxx's Avatar
Hey man, not sure if u found any other cams but I got a catalog from the truck shop and they offer them. There website is truckandcarshop.com
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 02-17-2016, 08:26 AM   #7
Katrina/10
Katrina/10's Avatar
I bought one of those Dorman brand cams 20 years ago, and it didn't work right then, either.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-17-2016, 11:16 AM   #8
kdh454
Rock Auto lists three brands that are not Dorman. Including one that is made in USA.
http://www.rockauto.com/en/catalog/c...ignal+cam,1572
kdh454 is offline   Reply With Quote
Old 02-17-2016, 11:37 AM   #9
truckin 79
Looks like you can buy a whole new turn signal switch with the wires for 34.00 from Autozone. I used one a long time ago on a Bronco and worked tons better than just replacing the cam itself.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-17-2016, 10:21 PM   #10
69heavychevy
69heavychevy's Avatar
I've given up buying electrical parts from rockauto. I've had terrible luck with them. I ordered the entire turn signal switch, thats made in the USA btw, and the turn signal contacts are starting to act up after 6 months of very light use. The hazard light switch doesn't operate correctly.
Neutral safety switch went bad after one week.
Ignition lock went bad after one month.
I just by my electrical parts from oreillys now, I usually try to buy their BWD line which have a lifetime warranty.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 02-17-2016, 11:05 PM   #11
1774btcrew
1774btcrew's Avatar
The whole switch isn't needed as usually all that is bad is just the cam. I don't sell my rebuilt columns for enough to justify purchasing a complete switch. It seems like the Shee Mar are pretty decent. They just aren't easy to purchase locally.
Old 02-18-2016, 12:53 AM   #12
lilpoindexter
lilpoindexter's Avatar
Im not sure who makes it, but i one from Classic Industries this weekend. The turn signal lever was too narrow for the slot on the cam...instead of moving with the cam, the lever pivots on the screw a little, and then it starts moving the cam. i looked at the original part, and the width of the lever was a snug fit on the cam...so both moved together. I am going to build up the width of the original turn signal lever with some JB weld, then file it down to fit the width of the new cam. I don't know who makes the classic industries one....and yes...my OG cam was brittle, and had cracked right at the screw where the lever screws on....Only got 38 years of use out of it...lol
lilpoindexter is offline   Reply With Quote
Old 02-18-2016, 10:44 AM   #13
1774btcrew
1774btcrew's Avatar
I am not sure why it is so difficult to get good ones of these! As I build these for customers, it gets really frustrating to do top quality work on a steering column and then have problems with the signal cancelling. I have also tried to get Autozone and O'Reilley auto parts to contact Dorman about this problem but as expected no one has followed through.
Old 03-30-2016, 06:47 PM   #14
Dead Parrot
Just finished replacing my switch. Looks to have been the factory original. It had the AC/Delco imprint on it. Went with the BWD from oreillys. #S3304 which their lookup says it the proper one for my 75. Switch works great. Installed fine.
Major problem with the electrical connector. Molding was not a match to the female connector on the truck. Since the switch was already installed, took a dremel to the new connector. Finally got it to go in only to find the last two contacts were spaced wrong. They were about a 1/2 contact width out of place. Wound up salvaging the original OEM connector housing from the bad switch and swapping it to the new switch. Then it plugged up great.
Don't know if Oreilly's lookup is wrong or BWD made it wrong.
Anyone know if there is a difference between the 75 signal connector and other years?
Dead Parrot is offline   Reply With Quote
Old 03-30-2016, 10:31 PM   #15
Front Range
Front Range's Avatar
Classic Parts sells just the switch cams
53-588 (73-76 with Tilt) 6.95 ea.
53-589 (73-76 without Tilt) and (77-91 All) 4.95 ea.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-31-2016, 12:07 AM   #16
1774btcrew
1774btcrew's Avatar
The issue is the 75 and earlier squares do have a shorter plug. The columns are also designed for this. If you are lucky enough to be able to save your plug, it is relatively easy to unpin yours and use it on the new switch. I usually do one wire at a time to not mix them up. That being said, many of the new switches you buy come with an adapter harness to work with the 75 and earlier trucks. These are considerably higher than the basic switch
Old 03-31-2016, 12:08 AM   #17
1774btcrew
1774btcrew's Avatar
Thanks for posting this, do you happen to know what brand they are?
Old 03-31-2016, 06:59 AM   #18
Dead Parrot
Thanks, mystery solved. The OReilly website lookup makes no mention of 75 and earlier being different, even though I had my 75 picked as the lookup vehicle. Swapping the pins was easy. And the 40 year old AC/Delco connector seemed in good shape. Before swapping one at a time, I also wrote the colors/letters down, just in case.
Old 03-31-2016, 09:46 AM   #19
Front Range
No I don't, but the phone number for Classic Parts is (1-800-741-1678).
Old 03-31-2016, 10:11 AM   #20
chrismoore701
chrismoore701's Avatar
I bought mine at the Chevy dealer
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-04-2016, 10:15 AM   #21
1774btcrew
1774btcrew's Avatar
Pins aren't bad to swap at all. The hard thing I find is coming up with early plugs. When I see them at the wrecking yard I grab them.
