Old 01-13-2016, 09:35 PM   #1
PeterHall
Power Steering Lines
I need to go from a rebuilt stock gear box to a Billet specialties power steering pump. Any tips?
PeterHall is offline   Reply With Quote
Old 01-14-2016, 05:26 PM   #2
kehstr
kehstr's Avatar
Re: Power Steering Lines
Do you have experience making lines? (Brake, transmission cooler, etc.)
kehstr is offline   Reply With Quote
Old 01-14-2016, 05:46 PM   #3
PeterHall
None at all but I'm pretty handy. A local shop said they can recriminations new rubber onto the line but not bend a line for me.
It looks like you buy "oem" lines that goes from the gear box to frame?
Old 01-14-2016, 05:52 PM   #4
kehstr
kehstr's Avatar
That sounds like the easiest way to me (buy a factory line, then have new rubber put on it to make it fit)
Bending the line, if needed, is really easy. Just put it in your vice and bend, a good rule of thumb would be to not bend it more than about 20-30 degrees than where it was before. If you really want to get serious, there are tools that will make it easier to bend the lines.
