Old 09-20-2003, 01:55 AM   #1
jorgensensc
jorgensensc's Avatar
Sway Bar Question?
Hey, kinda new to the website, and I have a couple of questions.
I have a '72 Chevy Cheyenne Super stepside (can't figure out how to post pic) and I want to put a swaybar on it. Can't seem to find the correct one localy, but I did find a massively thick one on a 77 c20. Would this work? The mounts measure about the same distance apart. Any help would be appreciated. Also, I have an oppurtunity to buy a complete A.C. system off of a truck (except the compressor) at a junkyard, should I get it for about 100.00??
Last question for now, I want to convert to the under the bed gas tank, also have an oppurtunity to buy a tank off of a Blazer, but it has a good 2 inch hole in the side. They want 25.00 for it, without a sending unit. I've got a guy who can weld it up for 20.00. Are metal tanks better or are plastic, or is that an opinion question? Thanks for your wisdom and insight, and if you can tell me how to post a pic I would love to sow off my pride and joy!!!
jorgensensc is offline   Reply With Quote
Old 09-20-2003, 02:01 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board.. THe sway bar will work... The a/c sound's like a good deal to me but j.m.o Steel gas tank's are better than poly cause they do not sag and can take a little abuse.. As far as posting pic's go to brouse at the end of the thread and pull your pic's off the computer...Hope this help's
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 02:03 AM   #3
68 Suburban
68 Suburban's Avatar
That one should work for you. Everyone should remember that a sway bar that is to thick, can be a detriment to handling too. In this case, thicker is not always better.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 09-20-2003, 02:15 AM   #4
jorgensensc
thanks for your quick response!!
How thick is too thick???
I'm going to try and post my pic now.....
Old 09-20-2003, 02:23 AM   #5
jorgensensc
maybe it will work this time?
Maybe this pic will work..
Old 09-20-2003, 02:27 AM   #6
jorgensensc
One more pic
Since I finally figured it out...
Old 09-20-2003, 02:34 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
wow beautiful truck!!!!!!! More pic's that truck is clean!!!
MEMBER #6377
Project "7DEUCE"
Old 09-20-2003, 02:39 AM   #8
68 Suburban
Re: thanks for your quick response!!
Im really not sure. But if you get one too thick, you will have an understear problem. Very nice truck. Personally, I would not go over 1 1/4 inches on the sway bar.
Old 09-20-2003, 02:42 AM   #9
68 Suburban
This is the one I have on my burb. It is off a 68 C-20 and has worked out well.
Old 09-20-2003, 02:47 AM   #10
jorgensensc
Thanks for the answers!!!!
I really appreciate when people help each other. Thanks for te kind words about my truck!!Here's another couple of pics, I just don't want to take up too much server space....
Old 09-20-2003, 02:51 AM   #11
jorgensensc
nice sway bar!!!!
This is before I installed my power brakes. I am installing my energy suspension cab mounts and panhard bushings tomorrow, any suggestions besides don't overtorque and lube really well? They were 54.00, and the original rubber mounts were 50.00, it made more sense to me to get the energy ones. Ever had any problems???? Heres another pic..
Old 09-20-2003, 02:57 AM   #12
jorgensensc
My next major project..
The next major project will be the gas tank conversion, then A.C., and somewhere in between refinishing the wood bed. Probably going to do the bed when I do the tank. This is my daily driver, so I use the bed pretty often.
Old 09-20-2003, 06:50 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I hate/love to see black trucks....
My truck, currently in primer, was black when it was new. When I see a picture of a black one, it just adds fuel to the fire. However, it's not that I don't want mine back in black, I would also like to have a red truck. Then, originality of color counts, doesn't it? Mine has the upper/lower side trim, which I don't really care for, at least not both. I think it would look better with just the lower trim. But, I like the 67-68 side trim better and wonder how it would look on my '69.
You have a very nice looking truck. California is kind to vehicles. My youngest son is stationed at Travis AFB, and wants to buy an early Blazer/Jimmy, "to play with". His first vehicle was a black '69 Fleetside C-10, which he regrets selling. It wasn't wrong to sell it, but it wasn't right to keep it and not drive it, either.
I also want to move my gas tank, but I'm not sold on putting it under the frame, ala Blazer/Suburban's. Since I don't actually haul much in my bed, I'm considering a bed-mounted tank that would be hidden by a tonneau cover, yet easily accessible.
I have factory A/C in my truck, too. I think that restoring the A/C is the way to go, even to the point of using a newer coolant, but not R134A. There is an R12 replacement, that is friendly to the environment, which I will use. I can't remember the brand name, but someone else will.
Oh, welcome to the board! There are truly a lot of helpful, friendly folks on here. Come visit often.
Member Nr. 2770
Old 09-20-2003, 08:49 AM   #14
Welcome to the board from South Mississippi.
Old 09-20-2003, 12:10 PM   #15
miket
miket's Avatar
Welcome to the finest 67-72 board around....sweet truck!!!
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-21-2003, 08:44 PM   #16
dinnut
dinnut's Avatar
sweet truck
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-21-2003, 09:38 PM   #17
bad 71 chevy
bad 71 chevy's Avatar
Nice truck and welcome and where are you from
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 09-21-2003, 10:18 PM   #18
jorgensensc
Thanks for all of the welcomes!!!
Thank you for all of the great welcomes!!!
To answer your question, I'm currently stationed at Camp Pendleton, Ca. (Marine) I have had many trucks to include a '80,'81,'82,and '83 Chevy Fullsize. Before I left for Iraq I had sold my 1991 S10 Short Bed regular cab that I had put a 1996 LT1 with a 6 speed tranny. When I came back I decided that life was too short and I wanted my dream truck. I immediately sold my '82 Short Bed and bougt this truck. I have never been so happy with a purcase. I got to spend the weekend working on it. I changed the body mounts (energy suspension) rear panhard bar bushings (same) Rear differential fluid, radiator coolant, thermostat, oil, greased all of the zerk fittings I could find, and hooked up all of the hoses for the windshield washers. I love it wen I get a ood weekend with no other cores to do. By the way, I'll be heading back to home to Texas When my enlistment is up in two months. This is probably more info than you wanted, but I felt like sharing. Thanks again for the great hospitality. I really do love this sight.
I promise I can spell, but the 'h' on my keyboard sticks, too bad I can't just grease that!!
Old 09-22-2003, 12:34 AM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That truck is the definition of sweet.
Welcome home, and welcome to teh board.
Where at in Texas are you headed...and how will you get all those trucks home?!
Old 09-22-2003, 01:10 AM   #20
jorgensensc
Thanks Longhorn Man!!
I don't have all of those trucks anymore. Right now all I have is the '72. I am moving back to Cypress Tx. when I get out. Just got a new house there with a 2 car garage that is screaming for another '72 built from the frame up!!! We will see once I get there!!
Old 09-22-2003, 01:34 AM   #21
Iron-Butt
454 club
Iron-Butt's Avatar
Welcome from Katy, Texas.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 09-23-2003, 12:12 AM   #22
Paul72
Paul72's Avatar
Welcome from MN. Thank you for defending our freedom!!!
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
