Old 01-14-2016, 11:10 AM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
4l60e swap...
whats up brothers... im needing some advice .. wanting to swap a 4l60e in a 68...it currently has a 383/350 combo... I know the tranny will mate with the smallblock.. what do I do about the computer..is there a kit I can buy..any info or direction will be appreciated
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-14-2016, 11:30 AM   #2
jokerz71
jokerz71's Avatar
Re: 4l60e swap...
First & foremost,you will need the controller.There are several vendors to choose from.A few are GM themselves,TCI, U.S. Shift. You will need a tach signal to the controller along with a TPS(throttle position sensor)mounted onto your carb linkage.The worst part of what you are trying to do is dealing with the speedo.The 4L60E uses a VSS to send pulses to the controller to run an electronic speedo.There is no provision for a mechanical speedo.There are conversion kits to do this,but,they are very expensive(approx. $500).It may be better for you to consider a 700R4.Just depends on how much you wanna put into it.
jokerz71 is offline   Reply With Quote
Old 01-14-2016, 11:50 AM   #3
PowerdbyChevy79
Re: 4l60e swap...
I have a Dakota digital already so I should be able to just hook it up....right?
1966 C10 "Mary"
Old 01-14-2016, 11:54 AM   #4
jokerz71
jokerz71's Avatar
Re: 4l60e swap...
I would think so.Not familiar with the Dakota.
Old 01-14-2016, 01:37 PM   #5
hugger6933
Re: 4l60e swap...
Thar Dakota box is similar to the Cable-x as far as what it does yes that should make it work for you. Go to E-Bay and look at trans computers or stand alone trans boxes. You can get the least expensive in the $500 range I think. If your 4L60E is from a LS motor you may need to check about spacers for the torque converter as the set back is farther than it is for a small block[ the distance between the flywheel and converter.]
hugger6933 is offline   Reply With Quote
Old 01-14-2016, 03:31 PM   #6
davepl
davepl's Avatar
Re: 4l60e swap...
Won't you need a throttle position sensor, or does the 4L60E still have a TV cable? I thought the E models did away with that, and need either a MAP and/or TPS sensor for the computer box to know what load you're under, kickdown, etc.
Not rocket science to add one, but it's not "standalone" in that the computer just hooks up to power and the transmission and you're done...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-14-2016, 03:42 PM   #7
Bigdav160
Bigdav160's Avatar
Re: 4l60e swap...
Yes, it needs the TPS signal.
I think a cleaner solution would be to rig one to the gas pedal. Some asian cars had a cable routed to a pulley. Pulley had the TPS mounted to it
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-14-2016, 08:40 PM   #8
Kennuck
Kennuck's Avatar
Re: 4l60e swap...
The 4L60E is basically an electronically controlled version of the 700r4. I don't see any advantage to do this over the 700r4? What are you hoping to gain?
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-14-2016, 08:44 PM   #9
PowerdbyChevy79
Re: 4l60e swap...
For when i get ready for a LS awap i will already have the tranny..my tranny is goin out and i dont want to pay for a rebuild i will only use for a couple years..
1966 C10 "Mary"
