Old 01-14-2016, 01:07 PM   #1
Coach529
Coach529's Avatar
S-10 IFS bagged question
OK, I have a Scott Danforth Cross Member going in a 1949 Chevy 3600. His cross member accepts S-10 and Metric donor parts.
The truck will be on bags.
Last night I mocked up the S-10 donor parts.
According to some rough measurements with a 27" tall tire, and stock spindles my running boards will be about 4" off the ground.
I am loosing some travel due to the upper ball joint binding up.
So the question is:
  • Pie cut stock UCA?
  • Buy Pro Forged Super Travel Upper Ball Joints
  • Buy Tubular Upper Control Arms
I plan on dehumping the Lower Control Arm to accept my bags.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-14-2016, 08:09 PM   #2
Coach529
Coach529's Avatar
Re: S-10 IFS bagged question
Anybody???
1949 Chevy 3600
Old 01-15-2016, 04:48 AM   #3
andrewmp6
Have you seen these http://michiganmetalworks.com/store/...&product_id=76
andrewmp6 is offline   Reply With Quote
Old 01-15-2016, 08:11 AM   #4
6DoF
6DoF's Avatar
if you have the fab skills, i'm a fan of the pie cut factory parts. i like the look of factory parts in an obviously custom build vs custom parts in a factory car, plus it's like 1000x cheaper for the exact same function.
6DoF is offline   Reply With Quote
Old 01-15-2016, 10:58 AM   #5
Coach529
Coach529's Avatar
Originally Posted by andrewmp6 View Post
Those are cool....but definitely not in the budget!!
1949 Chevy 3600
Old 01-15-2016, 11:07 AM   #6
Coach529
Coach529's Avatar
The Pro Forged Super Travel Ball Joints are supposed to have enough travel to take care of the problem, and are relatively cheap. $69.00 for the pair.
I think I am going to give them a shot......
1949 Chevy 3600
Old 01-15-2016, 01:18 PM   #7
6DoF
6DoF's Avatar
Love those
I hadn't found those yet ... are they simply angled joints, or do they have more angular travel?
Old 01-15-2016, 01:42 PM   #8
Coach529
Coach529's Avatar
Love those
http://www.summitracing.com/parts/po...0021/overview/
1949 Chevy 3600
Old 01-15-2016, 01:53 PM   #9
6DoF
6DoF's Avatar
gotcha, angled mounting flange ... same angular travel as stock.
just to make sure i have this clear in my head, you would still get the same total wheel travel with these, but that travel would be over a different range. the truck would sit lower at max, but not as high at max. if you need new ball joints, it's a pretty good option but the cut-n-weld is still virtually free and tune-able.
when i cut mine, i trimmed the end of the x-member and ditched the lower bumps first. this let me use the physical stop of the lower arm hitting the x-member as my lower limit. then when i cut the uppers, they were bent to exactly match this lower limit giving me the maximum possible extension before that joint topped out again. i actually cut them, bolted them back into the suspension, sat on the x-member to hit the lower limit of the lower arms, bent the upper arm in place til it stopped, and tacked it back together.
my way was a lot more work ...
