Old 01-14-2016, 04:06 PM   #1
66ChevyMax
66ChevyMax's Avatar
LS3 - Power Steering & Coil Relocation
I need to relocate the Power Steering Reservoir and Coils, anyone got some good ideas or pictures?
Thanks,
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 01-14-2016, 07:22 PM   #2
solidaxel
solidaxel's Avatar
Re: LS3 - Power Steering & Coil Relocation
NICE!
Watching this one!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-14-2016, 08:38 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LS3 - Power Steering & Coil Relocation
I have seen a coil setup that mounts underneath the headers on the frame. The plug wires all run straight down. Very clean looking.
I have also seen them mounted on the backside of the intake which by the pictures you posted would be a good time to make a bracket for them and route wiring.
On another note, what the plan for that power steering reservoir in the way of the throttle body?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-14-2016, 09:20 PM   #4
drfloyd
Nice setup. I'm partial to the coils mounted on the frame rail as Andy stated. That P/S reservoir appears to be the real issue.
drfloyd is offline   Reply With Quote
Old 01-15-2016, 01:11 PM   #5
solidaxel
solidaxel's Avatar
Have you looked at the aftermarket like Dirty Dingo or BilletSpecial.
Your stock bracket has some value if it is to be sold
LS 3 4L70E
Old 01-15-2016, 06:52 PM   #6
solidaxel
solidaxel's Avatar
That would be for the Alt P/S bracket
LS 3 4L70E
Old 01-15-2016, 10:19 PM   #7
Andy4639
Old member
Andy4639's Avatar
Mine is a truck motor LS so I guess that's the difference in the power steering.
Mine sits way lower on the motor.
Old 01-18-2016, 10:55 AM   #8
66ChevyMax
66ChevyMax's Avatar
Thanks for all the responses, I have a kit that will relocate the coils on top of the new valve covers so I will start there and see how that looks. As for the PS reservoir it's a bit more difficult. Finding a location for it I won't be the problem, getting the hose back to the pump could be difficult as it is tucked away right behind the current reservoir location. Getting through the belt may be a bit of a challenge.
Craig
Old 01-24-2016, 04:10 AM   #9
67chevy1series
67chevy1series's Avatar
I plan on running the corvette style accessory drive with the same power steering reservoir and I've done some research on how that all fits together... Seems to me since the inlet for the power steering fluid to enter the pump from the reservoir faces upward and to the passenger side the reservoir would need to be mount towards the passenger side of the pump for a more direct flow or line to the pump, problem is for that pump to be happy and live it's full life without any problems your not supposed to mount the reservoir or any reservoir lower then the level of the pump... So that only leaves you with keeping the one you have, where you have it, or mounting it kind of high up in the engine bay and having a long hose snake through to the pump.
67chevy1series is offline   Reply With Quote
Old 01-24-2016, 09:39 AM   #10
homemade87
My guess is that you will not be able to use that corvette pump and alt bracket that you have . You will have to go to the lower mount ps truck pump or similar . Most likely there is an aftermarket bracket that will do it . Looks like its time to start calling some of them .
Looks like you are going to have a nice set up when your done .
homemade87 is offline   Reply With Quote
Old 01-24-2016, 12:36 PM   #11
66ChevyMax
66ChevyMax's Avatar
67, I have to agree, magnuson makes a bracket to relocate the reservoir to the upper area on the passenger side, but as luck would have it the KWIK a/c is located in the location they use. I am going to try to find an alternate spot there as well. Passenger side is the only choice with this setup.
87, believe me I am making phone calls and may have to go with truck setup but if I've learned anything with custom trucks it is when you change 1 thing it creates 5 more problems.
Craig
Old 03-28-2016, 09:27 PM   #12
Chevy454lsx
I am in the process of installing the same blower as you with the same pulley set up. Just curious did you find a solution on the power steering reservoir and also what did you do with the coolant lines for blower that are right up against the Kwik ac mount?
Chevy454lsx is offline   Reply With Quote
Old 03-28-2016, 10:06 PM   #13
Robznob11
Robznob11's Avatar
Fortunately we live right down the road from Lubbock wrench a part and you can get that truck set up for pennies on the dollar and try it out ....nice to see a local with such a nice build ! I'm jealous!!!!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-28-2016, 10:31 PM   #14
66ChevyMax
66ChevyMax's Avatar
I ended up going with the Wegner Belt Drive, this thing is sweet and fixed all the problems. The PS reservoir will still be remote but can easily be located on the drivers side.
Craig
Old 03-28-2016, 11:07 PM   #15
Chevy454lsx
Very nice build. Yea I've seen that kit just didn't want to spend that kind of money on a serpentine set up
Old 03-30-2016, 05:40 PM   #16
66ChevyMax
66ChevyMax's Avatar
It wasn't cheap but it solved 2 of my issues, looks sweet and I like the isolated blower belt
Craig
Old 03-30-2016, 07:01 PM   #17
Chevy454lsx
Yes the isolated blower belt is a good design. I just found out Kwik makes a ac bracket to mount the Sanden Mini compressor down low runs off 4 rib crank pulley. Solved my problem
Old 03-31-2016, 09:21 AM   #18
66ChevyMax
66ChevyMax's Avatar
Here's what I did to relocate the coils:
Craig
Old 03-31-2016, 09:34 AM   #19
solidaxel
solidaxel's Avatar
Are the wires by MSD, and how long are they?
LS 3 4L70E
Old 03-31-2016, 09:48 AM   #20
66ChevyMax
66ChevyMax's Avatar
Yes MSD, it was a universal kit that I cut to length, I think the shortest is 18" and the longest a little over 24".
Craig
Old 03-31-2016, 10:11 AM   #21
solidaxel
solidaxel's Avatar
Thanks and keep up the nice work !!
LS 3 4L70E
Old 03-31-2016, 10:48 AM   #22
roushinator
roushinator's Avatar
Nice work! Clean install.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-31-2016, 08:11 PM   #23
Advanced Design
Advanced Design's Avatar
That looks very good!
I just saw this thread, started reading at the top and was going to suggest Wegner. They are on the consideration list for accessory drive for my build.
What are you perceptions about the product? Good quality, well designed?
Advanced Design is offline   Reply With Quote
Old 04-01-2016, 09:15 AM   #24
66ChevyMax
66ChevyMax's Avatar
The quality is top notch, the stationary fronts on the idlers will look cool when running. Went together in about 90 minutes, fit was spot on.
I highly recommend this kit!
Craig
Old 04-01-2016, 09:19 AM   #25
solidaxel
solidaxel's Avatar
My only concern with any aftermarket drives is a "sweeek" when something powers up!
LS 3 4L70E
