Robert Olson Transport
![]() Join Date: Oct 2002
What will direct swap trans?
I have a 74 six cylinder 3 speed on column. What trans four speed or better will bolt up directly to the bell housing and use the existing clutch etc. I do realize I will have to add a shifter
Re: What will direct swap trans?
Nv833/a833 will fit nicely
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
Cast Iron Saginaw should swap in as a Muncie and a T10
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Moderator
![]() Join Date: Oct 2008
The MY6 A833 usually has a Dodge bellhousing to transmission bolt pattern unless you get one of the dual pattern transmissions. You'll probably need to match the input shaft spline count on the clutch friction disc. It's not a common transmission.
The automobile Saginaw 4 speed is a drop in with the exception of the floor shifter hole. The stick will come up right next to the seat. It's not a common transmission. The SM465 will bolt to the bellhousing but you may have to change the friction disc to mate with the SM465 input splines... I would do that anyway once you have the transmission off. This transmission is very common. All of them will need you to perform the driveshaft dance... except maybe the Sagniaw 4 speed.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
![]() Join Date: Jul 2000
As mentioned above, a 60s-70s Muncie is the right length, and has the rear mounting holes in the right place, but make sure you know the input and output shaft spline count. As I recall, the Saginaw 3-speed has 10 in and 27 out. Most of the more common Muncie M20 wide ratio transmissions have 10 input and 27 output, but later models have 26 in, 32 out. Worst case, you'd have to get a new clutch disc and driveshaft yoke.
On another note, for those looking to convert to an auto trans, a TH350 with short (6") tail shaft is also the same length as a Saginaw 3-speed, and has 27 splines on the output shaft, so will bolt right up to the crossmember and driveshaft yoke.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Moderator
The TH700R4 is 27 spline too but it's longer than the TH350 or the Saginaw 3 speed
I'm going from sm465 to nv3500 and was told my couch setup would remain the same. If your for an a883 I'll have a 4x4 version soon.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
#8 | |
Moderator
If you're looking to get rid of it I'd post that MM7 A833 for sale on craigslist or fleabay. The Saginaw 3 & 4 speed, some Muncie M20 M21 M22 4 speeds, NP-A833 MY6, GM-SM465, and NV3500 use a 1-1/8" dia ten spline input shaft. They all had 27 spline output except the SM465 that has a fixed yoke output. So. The clutch disc and driveshaft will mate with all of them. I would highly recommend replacing the clutch friction disc and the throwout bearing... and giving a critical look at the flywheel and pressure plate contact surfaces while the transmission is off. I'd probably do the rear main seal and the transmission input seal as well... Not all Muncie M20, M21, & M22 had 10 spline in and 27 spline out. There are iterations of all 3 that had 26 spline input and 32 spline output. The TH700R4, 4L60, & TH350 had 27 spline output yokes. The TH400 has a 32 spline yoke. Case lengths vary so the driveshaft is subject to modification in some cases.
