Old 01-14-2016, 09:33 PM   #1
65standard
65standard's Avatar
Small back window?
Has anyone here converted to the small back window? I really like the look and I am thinking about cutting up my '85 C/10 to do this. I found a small back window 1976 to cut up as an organ donor.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 01-14-2016, 10:55 PM   #2
68c10owner
68c10owner's Avatar
Re: Small back window?
I'm thinking you mean 1967 instead of 1976. I've seen a pic of one somewhere. Didn't care for the look but to each his own man.
Anthony
68c10owner is offline   Reply With Quote
Old 01-14-2016, 11:44 PM   #3
1774btcrew
1774btcrew's Avatar
He means 76. Big 2 and 1/2 ton trucks had small back windows
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-15-2016, 01:43 AM   #4
68c10owner
68c10owner's Avatar
In a squarebody? Never seen one of those.
Anthony
Old 01-15-2016, 02:59 AM   #5
andrewmp6
Yeah the big topkick and kodiak used the same cab but had a small back window.
andrewmp6 is offline   Reply With Quote
Old 01-15-2016, 03:01 AM   #6
68c10owner
68c10owner's Avatar
Got any pics? Tried a Google search but could only find regular square bodys.
Anthony
Old 01-15-2016, 04:53 AM   #7
andrewmp6
Like this http://www.bigasstrux.com/88gmcC5000_exNavy.html
Old 01-15-2016, 07:18 AM   #8
D13
D13's Avatar
I can confirm that the 6500/7500 straight trucks have a smaller window cut out. From what i was measuring the cab back panel would fit. By using the whole panel rather than just the window, the welds are in the door frame and roof header just like factory.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-16-2016, 11:10 AM   #9
65standard
65standard's Avatar
The donor truck is a 1976 C/60 with small back window. I didn't notice if it has that big window size stamped into it like that white one picture. I'll check it out again. If it does, I'm not going to do this.
Old 01-16-2016, 11:52 AM   #10
bark
Yep, far as I've seen they are all like that, I've thought about it a couple times. But kinda like the stock big back window better
bark is offline   Reply With Quote
Old 01-16-2016, 04:23 PM   #11
65standard
65standard's Avatar
Yeah, this 1976 C/60 has the stamping in the back like that white one picture. Oh well not thinking about doing this anymore.
Old 01-17-2016, 01:36 AM   #12
91short
This is on an 88-98 truck but same could be done to the 73-87 trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=576171
91short is offline   Reply With Quote
Old 01-17-2016, 11:48 AM   #13
enaberif
Holy crap that is just gross.
enaberif is offline   Reply With Quote
Old 01-17-2016, 12:21 PM   #14
65standard
65standard's Avatar
I like it. I think the 1967-1972 small back window shape flows well with the square bodies. I know where a 1970 C/50 is with the small back window I could use as a donor.
Old 01-17-2016, 01:30 PM   #15
Gregski
Post Whore
Gregski's Avatar
Originally Posted by 68c10owner View Post
Got any pics? ...
I am just gonna post some pics from that site directly on to here for us to have an easier looksie as I also never seen these before
1988 GMC C5000
Gregski is offline   Reply With Quote
Old 01-18-2016, 02:17 AM   #16
andrewmp6
That site the guy takes the big trucks and makes huge pickups out of them.Look at some of his other builds he has crew cabs and one he made a super long bed pickup.
Old 01-23-2016, 10:17 PM   #17
65standard
65standard's Avatar
I cut up the 1970 C/50 for the small back window. I think it will look great on my 1985 C/10?
Old 01-23-2016, 11:48 PM   #18
65standard
65standard's Avatar
I separated the inner and outer skins so I can fit up one side at a time. Slowly trimming the outer skin. More to come...
Old 01-24-2016, 12:06 PM   #19
65standard
65standard's Avatar
I like it, but I think it would look better if the window opening was set up 1" higher.
Old 01-24-2016, 06:53 PM   #20
65standard
65standard's Avatar
Got the outer skin all fitted and tacked it.
Old 01-24-2016, 06:56 PM   #21
65standard
65standard's Avatar
Another angle
Old 01-24-2016, 08:13 PM   #22
68Timber
I know the pieces fit
68Timber's Avatar
I like it!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
