Old 01-15-2016, 02:01 AM   #1
hdff
hdff's Avatar
Firewall hole question
On the fire wall where the vacuum hoses and control cable for the ac go thru there a gummy type material around the hoses and seals up the hole. What is it and can I buy some?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 01-15-2016, 08:54 AM   #2
dazza
dazza's Avatar
Re: Firewall hole question
I think they call it press tape, it's used to stop the condensation build up on the suction line of the A/C so you don't have water dripping everywhere. Check vintageair.com or one of their distributors, maybe even summit carries it. Or better yet, maybe a board member!
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 01-15-2016, 09:36 AM   #3
Grumpy old man
Grumpy old man's Avatar
I use window tape works great ,won't leak.
Amazon.com: 3M 08612 Window-Weld 3/8" x 15'... Amazon.com: 3M 08612 Window-Weld 3/8" x 15'...
Grumpy old man is offline   Reply With Quote
Old 01-15-2016, 02:54 PM   #4
coppertone
Active Member
coppertone's Avatar
I bought some insulation tape at oreilly's ,used it to help seal my evaporator box in the engine compartment.Works great part #59010.
coppertone is offline   Reply With Quote
