Old 01-15-2016, 04:36 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
71 k10 axle shaft help
blew a pass side axle shaft in my 71 k10. its a dana 44 19 spline. it has the open u joint. what other trucks can i get the shaft from? or am i stuck looking for a shaft from a 71-72? thanx for the help.
ooimpalaoo is offline   Reply With Quote
Old 01-15-2016, 09:24 PM   #2
52napco
Re: 71 k10 axle shaft help
1972 and older had the smaller Dana 30 size joint. The outer would work but 1973 and newer
had the 297 joint.you can buy new from Randy s ring and pinion.
52napco is offline   Reply With Quote
Old 01-15-2016, 11:03 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 71 k10 axle shaft help
i have several 71-72 front shafts---i switch all my trucks over to 73 style which are much easier to find. you'll need the axle shafts AND spindles to do the swap. 73 style shafts are larger diameter in the center area of the shaft instead of being smaller diameter in the center area like 71-72. the seal area inside the spindle is machined smooth and uses a rubber "flapper" seal on the 73 style as opposed to the "pound in" seal on 71-72 style. if you're interested in one of my 71-72 shafts let me know-$50.00 plus shipping. i know this isn't the parts board, just trying to help out a fellow board member.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
