![]() Join Date: Sep 2015
RE: Floor Shifter Kit (automatic)?
I dropped my 1970 C-10 off at the Tranny shop for a rebuild on the 400 tranny. He had another truck there he was working on and it had a floor shifter and I liked the look of that. Can anyone suggest where to purchase one and which is the best bang for the buck?? Thanks in advance for and advice or suggestion
Larry 1970 Chevy Pickup C-10 Dodger Blue 305CI/Th400 auto trans Long Bed/Rally Wheels |
Re: Floor Shifter Kit (automatic)?
Do you have bucket's or a bench seat?
If bench then I would look at one that you have to pull a lever to get it to shift in any gear. I have had passengers kick them in neutral and down shift them before driving down the road with them setting in the middle of a bench seat with a floor shifter.
Terry Soon to be retired and moving to Bristol, TN. |
![]() Join Date: May 2014
I have a Lokar in mine. I love it.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Old member
I did a S-10 floor shifter in mine. I'm running the 4l80e so I wanted the over drive setting. I cut the console down and then made the frame for it and covered it.
Some day I'll have a full one installed. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Lokar
i use a b&m unimatic with a high hump
#7 | |
All about them K’s
![]() Join Date: Jun 2014
I've got the B&M light truck mega shifter in my 3100 and love it. It's got provisions for 3 and 4 speed autos and it has both normal and ratchet modes to either cruise or bang thru the gears.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() ![]() Join Date: Aug 2013
I did a B&M shifter with a console surrounding it, Its just right for reach because its the truck series that I believe are taller. It has provisions for back-up and neutral safety switch.
I put the B&M Mega Shifter in mine. The one for trucks has a taller console so it is at the right height for a bench seat. Mine also has a button in the handle to shift the Gear Vendor overdrive.
69 Chevy 4x4 383 Power ![]() |
