Old 01-15-2016, 09:09 PM   #1
1972Blaze
Two timing marks on balancer, which one to use?
I have been working on getting my truck tuned properly. Today I started working on checking some things with my mechanical advance and timing at WOT. As I was playing with the distributor position for the first time I saw two lines on my balancer. Can anyone look at this setup and tell me which line I should be using?
1972 K5 Blazer Cheyenne
1966 L72 Corvette Convertible
2016 GMC Yukon Denali
1972Blaze is offline   Reply With Quote
Old 01-15-2016, 09:24 PM   #2
toolboxchev
Re: Two timing marks on balancer, which one to use?
Part of figuring this out will have to have you bring your #1 cylinder to TDC. When you have that established you should be able to tell which mark to use.
Sorry I can not automatically give you an answer. You may also have to pull your distributor cap and make sure it is pointed at the #1 plug wire terminal. We have run across many a engine set up improperly.
toolboxchev is offline   Reply With Quote
