Old 01-16-2016, 03:47 PM   #1
44Don
44Don's Avatar
Brakes
So when I'm driving at low speeds and coming to a stop the brakes tend to feel like they are applying on and off. There is no ABS light but i was wondering if anyone else had tis problem and corrected it.
44Don is offline   Reply With Quote
Old 01-17-2016, 02:33 AM   #2
sntrym95
sntrym95's Avatar
Re: Brakes
How's the brake fluid level? Have you checked the rotors to make sure they aren't warped? Do you feel any difference in the pedal when the brakes feel like they are not applying?
Mike
sntrym95 is offline   Reply With Quote
Old 01-17-2016, 03:32 PM   #3
speedygonzales
speedygonzales's Avatar
Re: Brakes
Front rotors are warped. Get you new ones. Not even worth turning the old ones. Labor will cost you ad much as the new ones these days.
Bed the new pads in correctly and be sure you torque lug nuts by hand in 2 steps. No impact gun. I also suggest if you slam on the brakes to come to a stop, put the tranny in neutral so you can take your foot off the brake pedal. This will allow the pads to come away from the rotor to cool more evenly. Automatic tranny vehicles warp rotors quicker than manual vehicles because at a light, the brakes usually aren't applied on manual vehicles.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-18-2016, 09:17 AM   #4
speedygonzales
Do you feel the pedal pulsating?
Do you notice the pulsating pedal gets faster or slower as the vehicle speed is fast or slow? In other words as you approach a light, do you notice the pedal pulsation slows down as the vehicle slows down? If so that's warped rotors.
Pride and joy
