01-16-2016, 05:10 PM | #1 |
CB Radio question
Looking to add a CB radio to the hunting truck and new to the CB world. I'm finding a few on Craigslist and wanted to see if there is anything I need to know or what to look for before buying.
Thanks for the education.
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
01-16-2016, 07:13 PM | #2 |
Robert Olson Transport
Re: CB Radio question
well cbs are 40 channel and 23 channel but the 23 went out of production in the seventies. You can get brand new ones for like $65 at a truck stop ( Flying J Petro Loves etc) what exactly are you looking for a magnetic mount antenna or a permanent mount antenna?
01-16-2016, 07:41 PM | #3 |
The old 23 ch ones are cool - GM made some thru the late 70's for production vehicles like Trans Ams and Vettes thanks to Smokey and the Bandit. They are pricey though... I've bought a few (not of the GM ones) and I tend to search for the early 40 channel CBs that were the big names 'back then'. The ones that come to mind are Motorola, Realistic, Midland, RCA, etc. Cobras and Unidens seemed to come out toward the end of the mad CB era rush and have a lot of the market nowadays. I try to pick something that is similar to what I saw in mid-70's trucks of the day and that first set of brands usually seems to fit the bill. Things to look for - the main one is that it works (seems obvious, but a lot of sellers aren't forthcoming and tend to not want to test it for you. Good original mic is also a nice to have. Most all have underdash mounts included. If you want to spend the money, there are plenty that have never been out of the box still available. Good luck!
EDIT: one more big consideration is the antenna. If you don't care about adding a single or rabbit ears, then go for it, but it's also possible to use an AM/FM/CB singular antenna - have to look around for them a bit, but that's what GM did. |
01-17-2016, 01:50 PM | #4 | |
01-17-2016, 01:52 PM | #5 | |
01-17-2016, 02:38 PM | #6 |
Never thought my day job could cross over here!
As far as antennas go, you cannot beat a 102 inch whip. However, on my truck I use a cobra mag mount that works well. I had a radio shack stick mounted on the drivers rear camper shell hole. I never got to use it since the coax ended up being too short, then it got damaged by a washing machine. I have a Cobra WX ST II in the pickup. I mounted it on some factory holes below the factory radio. I have no idea what the holes are actually for, but they serve nicely as mointing points. Keep in mind all CBs put out the same 4 watts so there is no need to grab a super expensive one. I picked mine because it scans the CB band so I can hear all the conversations, it was a pleasant suprise its also not very large. The older CBs from the 70s and 80s are HUGE. |
01-17-2016, 02:42 PM | #7 |
You can kind of see the CB here.
01-17-2016, 02:49 PM | #8 |
Here's a better shot.
01-17-2016, 06:28 PM | #9 |
you can use the stock antenna, just need a splitter. this guy has two (I think - only one called out by part #) in the parts lot he's selling. not a bad price, I've paid between 35 and 70 for the splitters I've purchased. http://www.ebay.com/itm/NOS-GM-Radio...p2052191.m2338
GM Part # is 22010169 (Delco Antenna Am FM CB Radio Splitter) |
01-17-2016, 06:35 PM | #10 |
This is what I do to my trucks. Nice and clean. Only the hand held is visable.
https://www.cobra.com/products/recreational/c-75-wx-st Amazon.com : Firestik 4ft Firestik ® II FS Series...
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
01-17-2016, 08:03 PM | #11 | |
01-17-2016, 08:11 PM | #12 | |
EDIT: I think I just now got what you're saying - are you saying it will not work with the embedded antenna in a windshield (only) but will work with the stock fender mount am/fm? Seems I heard somewhere telescopic ones were not as good as the constant length ones, but not sure. Anyway, that makes more sense to me than how I may have originally misread your first post. I was imagining a trunk mounted cb whip, not the factory fender aerial. Just want to clarify - thanks! |
01-17-2016, 08:28 PM | #13 |
IIRC, Factory CB setups had the antenna mounted on or near the mirror on the trucks. I want to say this antenna was adjustable as well. This antenna was also used for regular AM/FM reception.
The windshield antenna cannot and will not work for CB radio. If by some miracle you don't burn up the radio, coax, or the actual antenna element you will find your range and reception to be extremely poor. Additionally the windshield antenna is 300 ohms, a CB radio looks for a 50 ohm load. This mismatch can damage the CB's output. A standard Delco whip antenna might be long enough to work, but most whip antennas are tuned to roughly 97.9 mHz. CB operates at 27 mHz. At anyrate I'd replace the coax going to the antenna since it is not designed to handle 4 watts. Though I have found standard cheapo houshold coax can take about 15 watts. (don't use household coax, it won't match to the radio properly) It could also be very likely the delco splitter is set to mate the CB to the factory fender antenna and will work just fine. Last edited by Liberty; 01-17-2016 at 08:36 PM. |
01-17-2016, 08:33 PM | #14 |
on my truck I went to a truck stiop and I have those tripod mirrors so I bought a mount that attaches to the mirror My wire comes in through a grommet into the door and runs through the tube I attached to the door and frame that would have power window and lock wiring in it. I ran it under the dashboard and to the CB... Mine is overkill I used a 4 ft fiberglass mast because I had one. On my Dodge I use the same kind of antenna mounted to the back rack that comes along the frame rail and into the passenger compartment through the firewall. Both CB mounts are under the dashboard
01-17-2016, 08:49 PM | #15 |
chiro - I'm glad you started this thread! Didn't mean to hijack - but appreciate the additional discussion, I've learned some good stuff - thanks guys.
01-18-2016, 12:18 PM | #16 |
No worries, I'm learning lots too.
01-18-2016, 12:23 PM | #17 |
even with the am fm cb antenna your range will be less than with an actual separate cb antenna
01-18-2016, 02:29 PM | #18 | |
01-18-2016, 02:30 PM | #19 | |
01-19-2016, 02:25 PM | #20 |
I haven't read all these comments so I may just be repeating information but avoid the 23 channel ones unless your after astetics. They tend to be more prone to issues mostly because they are getting old. Mount the antenna on the highest point or make sure the tip is above the highest point otherwise its not going to be very effective. On pickups I prefer to use mounts on the bed for a solid mount though if you've got a roll bar or headache rack those work pretty good too. Tool boxes are also great. As far as actual information goes it looks like you've gotten most of what you needed to know.
01-20-2016, 08:54 PM | #21 |
If you just want a CB radio and don't care about period correctness a Cobra 19 can be purchased for about $40 or so and will work fine. However you can spend considerably more and get something with more knobs and lights and bells and whistles.
Amazon.com: COBRA CB MOBILE COMPACT 40CH INST. CH... Run the longest antenna you can live with. 102" is always going to be your best bet. If using a shorter antenna mount it as high as you can with as much of it above the roof line as possible. Make sure the mount has a good clean metal to metal contact with the body of the vehicle and that the underside of the mount where the coax attaches to the antenna is also clean metal. Would be best to check your SWR, local CB radio shop (nearest interstate truck stop likely has one) may check/set your SWR for free or cheap if you don't have/get your own SWR meter. Don't worry about length of coax.. regardless of what you read about having to have 18' of it. You only need whatever will get from the radio to the antenna. Agreed old friend.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
01-22-2016, 10:27 AM | #22 |
78K & 79C Jimmys
I got lucky and found a working delco unit.
I got a power antenna, with Gm splitter .i dont use it. The windshield antenna works the am/fm. And I picked up a 20 wallmart CB mag mount for$20. Works ok, and I can put it away.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-22-2016, 11:00 AM | #23 | |
I know the pieces fit
If you want a magnetic base, this one works well. I used one for a few years on a pickup. http://www.wilsonantenna.com/sp/wils...na-kit-carded/ Firestik's work well too. Whatever radio you buy can be turned up to put out more watts (usually somewhere between double and triple stock output) while you're at the CB shop. It will give you more send range and doesn't cost much. |
01-22-2016, 06:43 PM | #24 |
As far as turning up the power to get more TX... you are only as good as the other guys radio. You may be able to talk 10 miles or 100s-1000s of miles but if the guy you are trying to talk to can only talk 1/2 mile what good is your big bad radio?
Sooo... Educate your buddies too.
01-23-2016, 10:29 AM | #25 |
If the swr is too far off, Transmitting will destroy cb components. Antennas designed for cb can usually be tuned, some others might be incapable of getting good swr. Otherwise it is all weighing performance and looks of various options. Wwtbd=what would the bandit do?
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
