Old 01-16-2016, 06:31 PM   #1
awitate
Lowering blocks trouble
So I got the U-bolts off of one side and the new U-bolts and blocks do not line up on the trailing arm.
Is there a step that I missed?
Removing panhard bar?
Taking both sides off 1st before putting everything back?
I know its probably something simple but I can't figure it out
awitate is offline   Reply With Quote
Old 01-17-2016, 12:08 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: Lowering blocks trouble
I had the same problem with my blocks when I installed them. I had to compress the u bolts a little to get them in the holes by lifting up on the axle as high as i could get it. A pic is on page 8 of my build if you want to see them in. What brand are your blocks?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-17-2016, 01:47 PM   #3
Jferrante
Jferrante's Avatar
Yup, same problem on my first truck. A PITA but they will eventually go in with a lot of cursing.
Jferrante is offline   Reply With Quote
