Old 01-16-2016, 08:16 PM   #1
OregonNed
OregonNed's Avatar
My heater clean-out project
My truck is down for the winter, so I decided it was high time to take out my heater box to once and for all rid it of the old mouse nest inside. I've had particles flying out since 2012 when I bought it. I thought I's share pictures along the way - though I know the subject has been documented at least a few times. Here goes:
As it sat when I pulled the powering wire:
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 01-16-2016, 08:16 PM   #2
OregonNed
OregonNed's Avatar
Re: My heater clean-out project
Removing the cable inside the cab:
Old 01-16-2016, 08:18 PM   #3
OregonNed
OregonNed's Avatar
Removing the heater hoses to drain the coolant. A handy Tupperwear container worked perfectly. Note: I already had the inner fenders pulled to paint this winter:
Old 01-16-2016, 08:18 PM   #4
OregonNed
OregonNed's Avatar
Here goes the top hose:
Old 01-16-2016, 08:21 PM   #5
OregonNed
OregonNed's Avatar
Hardware removed and box removed. With a little jiggling, it easily came out - clearing the still-attached hood hinge just fine. If there is any difficulty on the way back in, I will consider removing it:
Old 01-16-2016, 08:21 PM   #6
OregonNed
OregonNed's Avatar
Looking inside, the heater core is new and looks great! :
Old 01-16-2016, 08:23 PM   #7
OregonNed
OregonNed's Avatar
The fan looks ok - but is a little chewed up... mice? I may replace it before reassembly:
Old 01-16-2016, 08:24 PM   #8
OregonNed
OregonNed's Avatar
Now for the grisly pics!
Old 01-16-2016, 08:24 PM   #9
OregonNed
OregonNed's Avatar
Next
Old 01-16-2016, 08:26 PM   #10
OregonNed
OregonNed's Avatar
The dis assembly took about 30 minutes - now onto cleaning up parts. More to follow soon.
Old 01-16-2016, 09:05 PM   #11
wpavlis
I am in the middle of doing this now. Having trouble with the inner fender. I am a little scared of what I will find when I get it apart.
wpavlis is offline   Reply With Quote
Old 01-16-2016, 10:12 PM   #12
REEDS 72
REEDS 72's Avatar
mask&gloves
REEDS 72 is offline   Reply With Quote
Old 01-16-2016, 10:15 PM   #13
Grumpy old man
Grumpy old man's Avatar
Good thing there's no Hantavirus in Washington !
Grumpy old man is offline   Reply With Quote
Old 01-16-2016, 10:15 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Originally Posted by REEDS 72 View Post
mask&gloves
Yup...
Hanta Virus...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-16-2016, 11:11 PM   #15
Gromit
I'm guessing you might find Mr. Mouse's) skull and bones up between the sheet metal of the roof and the cab ceiling.. remove a sun visor and stick one of those borescope cameras through the sun visor swivel hole and fish around until you find him.. I think the mice can move up from the heater blower hamster wheel through the hollow front pillar to get into the space between the roof and ceiling sheet metal.. Lysol will help with hantavirus but don't rely on it (until they find a cure for the virtually certain death or at least permanent health effects of hantavirus)..
Gromit is offline   Reply With Quote
Old 01-17-2016, 12:30 AM   #16
zeldman
zeldman's Avatar
Hantavirus is serious, sometimes deadly serious. Please use a mask and gloves to remove and clean. Then use plenty of disinfectant like Lysol.
I have flown several people out sick with hantavirus. Its not something to take chances with.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-17-2016, 12:55 PM   #17
F.A.A.benny
They can be made to look pretty nice. I restored this one last month
F.A.A.benny is offline   Reply With Quote
Old 01-17-2016, 01:13 PM   #18
OregonNed
OregonNed's Avatar
That looks really nice! The brackets holding my core in are pretty rusty as well as the inner door having some surface rust (light)
Old 01-17-2016, 01:21 PM   #19
LockDoc
The Older Generation
LockDoc's Avatar
You got pretty lucky. It must have been cleaned out when they replaced the heater core. Here's what mine looked like.... You can tell by the size of the screwdriver how much stuff was in there.
LockDoc
Leon
Old 01-17-2016, 01:37 PM   #20
F.A.A.benny
Yea them rodents can leave a smelly mess. The last system I restored, I could not reuse the heater box. Even though it was bead blasted and clear coated, the smell would not go away
Old 01-17-2016, 01:39 PM   #21
F.A.A.benny
I always replate the brackets.
Old 01-17-2016, 01:50 PM   #22
OregonNed
OregonNed's Avatar
That was bad! I think a lot of my nest flew out using the heater the last few years. I looked for the brackets but couldn't find them. I ordered a new fan cage because mine was a bit chewed up.
Old 01-17-2016, 02:47 PM   #23
firedemon
mine was so full I don't know how the mouse fit in there anymore . I thought the fan was shot couldn't get air through any where and the doors were froze in place thought the cables were froze . works good now but there are rust holes on the inner box thinking mouse pee
firedemon is offline   Reply With Quote
Old 01-18-2016, 10:25 PM   #24
OregonNed
OregonNed's Avatar
Do you sell the rebuilds? Or just use them again.
Old 01-19-2016, 02:22 AM   #25
F.A.A.benny
I sell them. That went to a guy in Florida.
