Old 01-17-2016, 03:40 AM   #1
MiraclePieCo
MiraclePieCo's Avatar
Side window help?
I ordered the side window run channels for my '50 AD PU (no vent wings). I assume lots of you guys have done this before, so how do you remove the glass and how do you get the run channels down inside the door? Step by step video would be nice, or just come over to my house and do it for me
MiraclePieCo is offline   Reply With Quote
Old 01-17-2016, 10:32 PM   #2
youngrodder
youngrodder's Avatar
Re: Side window help?
It would not be the easiest thing to video tape. You will need to remove the inner window molding that goes around the window opening of the door. Then you will need to remove the bolts (I think there are 4) that hold the glass to the horizontal channel that runs at the bottom of the glass. You will need to roll the glass down some to access all of the bolts in this channel. Once the glass is unbolted from the channel, roll down the window the rest of the way. This will allow you to rotate the glass in order to remove the glass.
The window channel just presses in. It is pretty straightforward.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-17-2016, 11:26 PM   #3
MARTINSR
MARTINSR's Avatar
Did the factory channel just press in? I had mine screwed in with little screws through the center of it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-18-2016, 04:20 AM   #4
MiraclePieCo
Thanks for the help, youngrodder. I found an old instructional photo that shows just how you described it:
