Old 09-20-2003, 04:38 PM   #1
67 C-10 LWB
67 C-10 LWB's Avatar
F/S 67 C-10 LWB in Michigan
Hi all, I'm selling my 67 Chevy pickup as the subject says. It has a 69 327 out of an Impala, it was rebuilt about 2 years, only put approx 4000 miles on it since. Runs great. bored it .030 over, cast pistons, crank ground .10/.10, Edelbrock Performer RPM heads (polished) Edelbrock Performer Intake, have Performer RPM as well to go w/ it, Edelbrock 750 CFM carb w/ electric Choke, and HEI distributor. 3 speed on the column. 3.08 open rear end. headers (unknown brand), 2 1/2 inch exhaust w/ 50 series Flowmasters exiting out rear.
Bench seat, factory only had speedo and fuel gauge and the normal idiot lights, has 3 after gauges mounted on bottom dash (oil, amp, tem) amp doesnt work, or isn't hooked up. After market Sony Xplode cassette deck in dash and Sony Xplode 10 disc changer mounted in glove compartment.
Has normal rust for front inner fender, both have holes towards front.
Body rust: driver fender has some small bubbles on bottom towards door, drivers door has bubbling/cracking at the corners. Passenger door has bubbling on bottom corner towards back of cab. I havne't done any paint/body work to it so unknown if it has bondo. Has 15" turbine rims, 8" in front (225/50/15 I think) and 10" in back (275/60/15). Chrome sport bumpers, 3 or 4 years old, no problems w/ them. the letter H on the hood feel off, still have it, the mount post broke though, small suface rust spot where that was at, easy fix.
This truck would make an excellent daily driver, or project truck. Only left me stranded twice, it was on the same trip, water pump went out, got it fixed and then on the same night the valve spring broke and dropped the valve in the cylinder and the piston shattered basically and some pieces shot out the oil pan and the rod put a nice hole in the cylinder wall. But I have fixed that w/ a new engine and have had no problems at all since then. Asking $4000.00. I am getting married soon and have a house and need the money. Thanks for looking
Pics can be found at HERE
Ean
1999 Silverado Ext Cab Short Box Z71
2006 Trailblazer (wifes)
2 '04 KFX400's
My Site
67 C-10 LWB is offline   Reply With Quote
