Old 01-17-2016, 04:14 PM   #1
weider1717
needs some help from owners of 87's that are very original
I need to know what clamp came on the coolant tank hose stock. My truck when I bought it years ago the owner had put one of those after market tanks due to the original tanks leaking I assume and it had a regular ole #6 hose clamp on it i have put a oem tank back and looking at that clamp I would just assume it isn't original that GM put that kind of clamp on it..looks ghetto.
so if anyone is nice enough to take a look or even a picture I would really appreciate it because none of the google images shows that area in the engine bay it's always blocked!
weider1717 is offline   Reply With Quote
Old 01-17-2016, 04:28 PM   #2
MikeB
MikeB's Avatar
Re: needs some help from owners of 87's that are very original
Not sure if it's the same as an 87, but my overflow hose clamp looks like this, and it's olive drab in color.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-17-2016, 04:39 PM   #3
weider1717
thats what i figured! thanks so much. Now I got to see where I can find one.
Old 01-17-2016, 04:46 PM   #4
MikeB
MikeB's Avatar
In fact, virtually all of my smaller hoses use that type of clamp -- fuel line, tank vent lines, lines to evap canister, etc.
Mike
Old 01-17-2016, 04:47 PM   #5
weider1717
I just stepped out and looked and mine has that clamp you describe on the radiator end of the hose.
I am talking about the coolant tank end so just to be sure you're saying yours has that same clamp on the tank end that is on the radiator end also correct?
thanks again
Old 01-17-2016, 06:22 PM   #6
MikeB
MikeB's Avatar
thanks again
No, the radiator neck end.
My tank has a nipple that the hose pushes into. Looks like there may have been some kind of clamp on the nipple at one time. Weird, huh?
Mike
Old 01-17-2016, 08:13 PM   #7
weider1717
Ah ok well I have the correct clamp to the radiator end and my tank indifferent mine has a nipple that the hose fits over and thats where the regular hose clamp is that I am assuming isn't the way it came.
Old 01-18-2016, 02:06 PM   #8
weider1717
anyone else? as I still don't know. thanks
Old 01-18-2016, 03:32 PM   #9
83GMCK2500
Keith is the first one that comes to mind to answer this best...perhaps he's lurking.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-18-2016, 05:35 PM   #10
Keith Seymore
Keith Seymore's Avatar
Sorry - I kept forgetting to take a pic.
Mine has a small crimp clamp at the surge tank. It is called an Oetiker clamp, after the manufacturer.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-18-2016, 05:36 PM   #11
Keith Seymore
1979-1986
1986 - 2019
Old 01-18-2016, 06:15 PM   #12
weider1717
thanks keith! is yours an 87 if not should I assume it's the same for my year? thanks so much.
Old 01-18-2016, 07:21 PM   #13
Chrispbrown36
It's pretty damn cold outside so I won't be stepping out to check right now, but I am pretty sure my 87 has the style like MikeB posted only they are black not green.
Chrispbrown36 is offline   Reply With Quote
Old 01-18-2016, 07:28 PM   #14
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The clamp Keith showed is original for 85-87 and through 91 on the RV designated crew cabs, suburbans and blazers.
The pic above that with the was the 81-84 overflow/recovery tank.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 01-19-2016, 07:09 AM   #15
Keith Seymore
Yes - mine is an '87 and I would expect all 87's to be the same (regardless of build location).
K
Rotated upright:
1979-1986
1986 - 2019
Old 01-19-2016, 11:30 AM   #16
ZacharyDouglas1992
just to solidify the above, my 87 R10 also has an "Oetiker clamp", which before this post I did not know the name of haha.
1967 CHEVELLE MALIBU 427/700R4
1971 CHEYENNE 10 350/350
1983 GMC K3500 454/400/205
1987 R10 TBI 350/700R4
2014 CRUZE 2.0 TURBO DIESEL
ZacharyDouglas1992 is offline   Reply With Quote
Old 01-19-2016, 12:52 PM   #17
weider1717
Same here pal now the question is what size and where to get one! I assume it's black or bare and just dirty.
Old 01-27-2016, 10:10 AM   #18
weider1717
anyone have a gm part # for this clamp or able to tell which size on ebay etc would be correct I don't have enough info to order one. thanks
Old 01-27-2016, 11:07 AM   #19
bhc41051
bhc41051's Avatar
You'll need the crimping tool as well
bhc41051 is offline   Reply With Quote
Old 01-27-2016, 11:41 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Unless your are dead set on a 100% accurate restoration, I would use the clamps pictured. They are a GM correct style, and much easier to acquire and service.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-27-2016, 12:15 PM   #21
Keith Seymore
Part number not available; Service parts shows a worm clamp.
K
1979-1986
1986 - 2019
Old 01-27-2016, 01:44 PM   #22
jetmech85
Try MSC Industries.
jetmech85 is offline   Reply With Quote
Old 01-27-2016, 06:29 PM   #23
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Wink Re: needs some help from owners of 87's that are very original
I have had my truck since new and the crimp clamp is what mine came with.
But! there was a recall on the surge tank's cuz the nipple would crack and fall off, GM replaced the tank with a new one that contained a brass tube in the nipple. When they replaced mine the replacement tank had the crimp clamp and hose attached but they put a worm style at the Rad end. I cant remember if there was a crimp style there or not from the factory.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-27-2016, 11:19 PM   #24
87ChevyR10
My truck has the same clamp as Keith shows.
I'm right there with you on keeping the truck 100% original! Keep us posted on your searches!
1987 R10 Silverado
87ChevyR10 is offline   Reply With Quote
