01-17-2016, 05:43 PM | #1 |
62 c10 ride height question.
62 c10 longbox disc brake front end swapped from a 78...5x5 bolt pattern.
3" drop spindles in the front but truck sits front high. Ls swapped 5.3..Do you guys cut the front springs to lower after installing drop spindles? If so How much do I cut to lower 2 more inches?..Thanks here's a pic or 2. |
01-17-2016, 07:22 PM | #2 |
Re: 62 c10 ride height question.
not sure how much to cut off your coils to get your 2" drop but you can get 2" drop springs from Summit for $125.00 a pair.
http://www.summitracing.com/parts/djm-cs2353-2/reviews/ |
01-17-2016, 08:02 PM | #3 |
If the pictures are with the 3" drop spindles something is wrong. Get some pictures of the from suspension up so we can check it out.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
01-17-2016, 08:10 PM | #4 |
I agree. With 3" spindles it should sit a heck of a lot lower in the front.
AIR ASSAULT |
01-17-2016, 08:30 PM | #5 |
Couple of things that may be contributing to the stance. First are the front springs sitting in the pocket correctly? This would be first place I would look as it happens a good bit. Second is there are still a lot of parts to put on that truck that will ad weight to the front of the truck. If you are sure the springs are in right I would not cut coil till the truck is assembled. And are you sure they are 3"? Going by what I can see from the pics, the lower a arms don't look real low on the wheel.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-17-2016, 08:31 PM | #6 |
Yes the 3" drop spindles are installed...I don't know the donor vehicle for the front end..it was installed when I bought the truck...I compared the spindles to the ones I removed and they are 3" different. I will post some front end pictures..
01-17-2016, 08:56 PM | #7 | |
01-17-2016, 09:35 PM | #8 |
Front of truck looks stock height to me, and is it me or the photo, passenger side looks higher. also you said Spindles were 3" different? .... 2 1/2" drop Spindle should be close to center up and down between ball joints. Not criticizing, just trying to help.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
01-17-2016, 10:06 PM | #9 |
My Truck is a 66' with 86' cross member swap 5.3 / 4l60e with 2.5" drop spindles and 2" front lowering springs. The rear has 4" lowering springs.
It only has original paint once Last edited by Mathew21; 01-18-2016 at 09:09 AM. |
01-17-2016, 11:52 PM | #10 |
Went out and took a look at the spring pockets...looks like the coils are not seated correctly in the pockets. I installed the drop spindles with the engine out as I replaced all the control arm related bushings at same time..and I had a hard time getting the coils to seat without the weight of the engine on the front end..(i would jack up lower control arm and whole front end would lift) Hopefully that will get me lower in the front end. Any tricks to getting them seated in the pockets?
01-17-2016, 11:54 PM | #11 |
01-18-2016, 06:28 AM | #12 |
See if you can barrow spring compressor from O'rieilly's, Auto zone, Napa...
01-18-2016, 08:54 AM | #13 |
As long as you get them centered around the spigot as you go up they will stay there. If you are pulling them out cut a 1/2 wrap off the bottom of the spring. Spring is smaller around at the top. Round off the sharp edges after you cut them. Then adjust the ride height lower if you want after the truck is done.
Jimmy
01-20-2016, 11:51 PM | #14 |
Re: 62 c10 ride height question. Updated>>
Trimmed 1-1/2 coils of the springs and installed them in the bucket correctly..Thanks for the replies! It now looks like this.
