Old 01-17-2016, 07:00 PM   #1
Shtudwn
66 Standard Steering Wheel and Horn Button Assembly
Hello,
I see a ton of links but not exactly what I am looking for.
When I bought my 66 the previous owner had installed a automatic column in it. It is a column from the same era and not something newer. Anyway, I have installed a 66 standard steering wheel and having a heck of a time finding accurate information on the steering wheel assembly for 1966. Everything from "is there a spring" to cancelling cam and horn assembly instructions w/ pics.
Can anyone enlighten me?
For example, I didnt have a cancelling cam on the steering wheel and now that I add it it appears that I no longer need the spring that was on the steering shaft. Is this correct?
Thank you for your help.
Dan
Shtudwn is offline   Reply With Quote
Old 01-17-2016, 07:24 PM   #2
DPowers
DPowers's Avatar
Re: 66 Standard Steering Wheel and Horn Button Assembly
How did you add the canceling cam?
The back of the wheel should look something like this:
DPowers is offline   Reply With Quote
Old 01-18-2016, 01:51 PM   #3
Shtudwn
Thank you Dpowers. Yes, now that I have installed the cancelling cam it looks just like that. Is there still a shaft spring between the wheel and the bearing? I put mine back together without it cuz it doesnt seem like it will fit with one.
Dan
Old 01-18-2016, 03:44 PM   #4
DPowers
DPowers's Avatar
There is a spring. Do you know what column you have exactly?
http://67-72chevytrucks.com/vboard/s...d.php?t=323448
