Old 09-20-2003, 05:13 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Its Here , Its Here
My new Currie Enterprize F@rd 9" Posi rear end is here.
But they forgot to send the Trac Bar, So I cant install untill next week-end
I'm so happy, Yet so bumded.
Soon to Be
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-20-2003, 05:16 PM   #2
chevykid1969
chevykid1969's Avatar
Looks $$$$$$
chevykid1969 is offline   Reply With Quote
Old 09-20-2003, 05:19 PM   #3
superchevy
Got big-block?
superchevy's Avatar
Sweet!
If / when I grenade my 3.73 posi 12 bolt in Daisycutter, that looks like what I'll need to get.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 09-20-2003, 09:49 PM   #4
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
sweet theyre just teasing you it will be there in a day or 2
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 09-20-2003, 09:53 PM   #5
dinnut
dinnut's Avatar
damn thats sweeet
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-21-2003, 11:14 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Abuddie of mine had 2 currie axle's built for his early bronco and when the axle's arrived they were also missing some item's..(2 trusses and plateing on the bottom of the pumpkin were not there) Does currie screw up order's alot????
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-21-2003, 10:50 PM   #7
1970 CST Short Wide
Senior Moment
Man I hope not
Pittsburg Ca
94565
Old 09-21-2003, 11:01 PM   #8
Injected68LS1
Injected68LS1's Avatar
That looks great! Just how much was that setup? Did they know exactly where to put the control arm pads?
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 09-22-2003, 10:35 AM   #9
1970 CST Short Wide
Senior Moment
$2100 plus shipping $150 . I measured and gave them what I had and they said, " Thats want we have" . I'm sure I'm not the 1st 67-72 they have built one for. When it arrived I re-measured and it looks good to me. If they wouldn't have forgotten the Trac -Bar it would be in trhe truck and I would be a happy camper
Pittsburg Ca
94565
Old 09-22-2003, 12:02 PM   #10
bigvinnie
bigvinnie's Avatar
I'm curious.... What is it about the ford rears that makes them superior to the GM units..???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 09-22-2003, 02:44 PM   #11
1970 CST Short Wide
Senior Moment
To be perfectly honest Vinnie I don’t know for sure. I know the gears are beefier and are supposed to be stronger. I needed to have my rear end done and it was going to cost ~$1500 (yes I know some guys do it cheaper) so I figured for another ~$500 - $600 Why Not
Pittsburg Ca
94565
Old 09-22-2003, 02:52 PM   #12
lukecp
Formerly yellow72custom
lukecp's Avatar
The Ford rears have a modular center section. If you decide you want to switch gear ratios, simply drop out the center section and put in a new one.
If you want to swap rears on a non-modular rear (such as a 12 bolt Chevy), you have to completley dismantle it, and install new gears to precision tolerances. Gears, parts and isntallation can easily run up to over $500, much more if you want a posi unit.
The more expensive yards around here want $150 for a complete 9" center section with 3.50 gears and positraction......defenitly much easier and cheaper to deal with
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
