1976 seat in a 1985?
Are the seat tracks the same for a 1976 and a 1985? If not, can I install my 1985 tracks onto the 1976 seat?
Anthony |
![]() Join Date: Oct 2014
Re: 1976 seat in a 1985?
I believe the only difference in the tracks are that the 76, the seat release will be off to the left of the seat. The 85 track, will have the seat release in the front.
You have to use your 76 tracks with your 76 seat and it will bolt right up to your 85 floor.
Thanks guys. I don't have the 1976 seat but I found one that is very nice and is the correct color for my 1985 but I didn't know if there was a difference in the floor pans or bolt holes. My seat is pretty uncomfortable, springs worn or broke and feels like I'm sitting on the frame. Didn't want to buy the seat if it wouldnt be a direct fit. Sounds like it will work fine though. Thanks.
Anthony |
i have a 78 in my 81 no problem with 78 tracks. only problem is seat belts have to route in between bottom and back instead of having holes in the bottom to come up through.
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
That's a problem I can live with if it means having a actual seat cushion to sit on.
Anthony |
Awhile back before I sold my 79, I was going to swap its seat into my 85 because it was way nicer. I pulled it out and noticed it wouldn't bolt right in unless swapping tracks and the guy who bought it was coming the next day to get it so I didn't have time to switch them out. Oh well, a maroon seat would't have looked good in a brown truck anyways..... Might as well just redo my current seat.
85' GMC Sierra Classic Built 350; Weiand intake, Holley 600, Thumpr Cam Built 350 turbo with shift kit & 2500 Stall Thumpin' away |
#8 | |
![]() Join Date: Jun 2009
As long as the tracks you are using match the year of seat you will be fine. Not to say every year is different but I know on the newer trucks, the bolt pattern on the underside of the seat was a different configuration.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
I'm not sure if the seat has the tracks or not actually. It's 2 hours away and I cant get over there til the weekend. Hopefully its still there because I need a seat badly.
Anthony |
![]() Join Date: Feb 2003
I'm wanting to replace the seat in my 83 Silverado with the seat out of an 80 GMC. Will it bolt right in or do I need to change out the tracks?
Thanks. |
As long as the 80 seat has the tracks, your fine, it will bolt right up. All the seats from 73-87 will bolt up to the cab floor. What makes the differenc, is that the track has to match the frame of the seat.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#13 |
Thanks, TKCR. I do appreciate the info.
#14 |
