Old 01-18-2016, 11:43 AM   #1
rgunlock
rgunlock's Avatar
Steering column rebuild question
I'm about ready to install the column in my 78 GMC. While its still out I would like to deal with anything that is likely worn. It is a non-tilt column and I've got a 4-speed floor shift so this is a pretty basic column. I know that I want to replace the rubber boot on the steering coupler as well as the rag joint. I haven't had a chance to drive the truck enough to know whether there were other problems or not.
What would you replace while you were at it? Anyone with a good link to a column rebuild?
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-18-2016, 02:10 PM   #2
chrismoore701
chrismoore701's Avatar
Re: Steering column rebuild question
ignition and safety neutral switches
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 01-19-2016, 03:11 PM   #3
rgunlock
rgunlock's Avatar
Thanks Chris. Is there actually a neutral safety switch in the column for manual transmission?
Rick
Old 01-20-2016, 08:37 AM   #4
chrismoore701
I am not sure how it works, but it may be hooked up to the clutch. Good luck. I took a 1977 straight, a 1979 straight - damaged, and a 1979 tilt - damaged, and combined to make a 1979 tilt. wow what a challenge.
Chris
Old 01-20-2016, 08:09 PM   #5
ray_mcavoy
No, the manual transmission columns don't have a neutral safety switch. Instead, there is a clutch safety switch mounted on the pedal hanger bracket.
ray_mcavoy is offline   Reply With Quote
Old 01-21-2016, 08:28 AM   #6
rgunlock
rgunlock's Avatar
So the ignition switch is the main thing to take care of while the column is out. Thanks for the suggestions.
Rick
Old 01-21-2016, 09:21 AM   #7
MikeB
MikeB's Avatar
It's difficult, if not impossible, to adjust the switch once the column is bolted to the dash. GM did this intentionally to reduce the chances of theft. So be sure to check switch operation first.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-21-2016, 09:51 AM   #8
tommy217xxx
tommy217xxx's Avatar
Good luck trying to find the coupler boot. I couldn't find one at all.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 01-21-2016, 10:08 AM   #9
MikeB
MikeB's Avatar
I'd also clean and lube the top and bottom bearings. The grease tends to dry out over the years.
Mike
Old 01-21-2016, 04:52 PM   #10
rgunlock
rgunlock's Avatar
Searching around, I found this link http://www.quadratec.com/products/918018_02.htm provided by member raggedjim that is supposed to be a usable replacement. I've ordered one, so I hope he's right.
Thanks for the additional suggestions MikeB.
Rick
Old 01-21-2016, 07:24 PM   #11
tommy217xxx
Let's us know how that boot works out. I had 2 intermediate shafts one with a good boot and one with a bad boot. So I just swapped the boots around.
TJ
80 Chevy c10 lwb
305/350
Old 02-26-2016, 10:55 AM   #12
First c10
First c10's Avatar
thought I would post this
pretty good write up
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-26-2016, 03:20 PM   #13
Scott76
Anyone know whether our gen trucks have the 'key presence switch'?
My fasten set belt light stays on all the time, even with the vehicle off and the key out of the ignition.
The senor on the retractor is not hooked up, but it still seems strange to me that it would stay lit even turned off and with the key out.
Scott76 is offline   Reply With Quote
Old 03-20-2016, 03:57 PM   #14
rgunlock
rgunlock's Avatar
Its been a while since I posted this question, but I did get the Jeep steering coupler boot. Came as a kit. The parts appeared to fit fine. The boot looks pretty good although I kind of mangled the plate in the base of the boot trying to get it over the pin in the shaft. I suspect that there is a better way to go about that job.
While I had the column apart, I ended up replacing the ignition switch, turn signal switch assembly and lower column bearings.
Rick
