Old 01-18-2016, 03:44 PM   #1
LT4XTREME
cool snowblower on a GMC
Seen this cool snowblower conversion on a GMC thought you guys might like to see it.
http://www.nh1.com/news/colebrook-ma...-long-winters/
LT4XTREME is offline   Reply With Quote
Old 01-18-2016, 04:16 PM   #2
Davidf
Re: cool snowblower on a GMC
Too cool. Funny that he uses a block of wood to set the power plant RPM. Since he has a full gauge package and starter button for the power plant in the cab of the truck, why not setup a simple push/pull throttle cable? 99% of the way there, come one, get to 100%
Davidf is offline   Reply With Quote
Old 01-18-2016, 04:19 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Kinda cool...
This is the first thing I thought of.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-18-2016, 04:32 PM   #4
bill3rail
bill3rail's Avatar
Love it!
My friend has a '69 GMC, and he'll get a kick out of this video.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 01-18-2016, 08:44 PM   #5
fp1967
fp1967's Avatar
Being from snow country myself, I like it. Thanks for posting this.
fp1967 is offline   Reply With Quote
Old 01-19-2016, 11:37 AM   #6
LT4XTREME
Yeah I thought that was funny also. I'm just not sure why he used the rear mounted diesel engine in the first place (besides extra weight in the rear) Since it has a standard trans most likely a SM465 I would have just used a trans mounted PTO and pump but that probably would not have the RPMs to turn the pump. Looked at a dump truck once that had the trans mounted PTO and pump and had a second pump mounted directly on the front of the engine with a coupling between the crank pulley and the pump.
Old 01-19-2016, 06:00 PM   #7
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Old guy probably had the 3-53 lying around and it's triple purpose... runs the hydraulic pump, provides winter weight and causes you to go deaf. What more could you need!! Probably didn't want to use the PTO because you would lose snowblower whenever you push the clutch in and you would have to keep the truck wound tight to keep the snowblower going!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 01-19-2016, 06:59 PM   #8
Boog
laying low
Boog's Avatar
That's some engineering right there.
Boog
Old 01-19-2016, 07:25 PM   #9
vidman
vidman's Avatar
Love that flashing light..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 01-19-2016, 08:52 PM   #10
snipescastle2
snipescastle2's Avatar
Talking Re: cool snowblower on a GMC
that's cool, but I still like the V8 Snow blower......
http://www.chonday.com/Videos/snowblowvch1
Ben
snipescastle2 is offline   Reply With Quote
Old 01-20-2016, 02:01 PM   #11
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Ingenuity at its finest!
We could have used that years ago when I grew up in Maine. All Granddad had at the time was a Simplicity garden tractor with a snow blade on the front. took hours to do our 200' driveway.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 01-20-2016, 02:28 PM   #12
That's the classiest personal snow blower yet! I believe the real deal Oshkoshes, etc, all have auxiliary power to run the blower:
Old 01-20-2016, 04:38 PM   #13
Boog
laying low
Boog's Avatar
Hey that V8 powered blower is cool too on a whole other level. 😎
Boog
Old 01-20-2016, 05:17 PM   #14
72MARIO
72MARIO's Avatar
I actually have seen that 454 snow blower the builder/owner uses it to clear his driveway. Its just south of me in Bracebridge
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-20-2016, 06:01 PM   #15
Boog
laying low
Boog's Avatar
You can probably hear it. 😉
Boog
