Old 01-18-2016, 06:56 PM   #1
sampsmit000
sampsmit000's Avatar
A/C Heat
Does anyone recommend a complete kit for an ac/heat unit. I was thinking of this one http://www.classicindustries.com/pro...s/ap6600d.html. Anyone have recommendations?
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 01-18-2016, 07:42 PM   #2
dodgiesdad
dodgiesdad's Avatar
Re: A/C Heat
I am installing an old air system in my truck it is also available as a complete kit. (http://www.oldairproducts.com/catalo...te-p-8304.html) I loved the factory look of the control with their kit. They also let me swap vents for ones which I mounted in my dash.
dodgiesdad is offline   Reply With Quote
Old 01-18-2016, 08:59 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: A/C Heat
I have Old Air installed and have had it at least 10 years. it work great but, if I was doing it now, I would go with Vintage Air, hands down.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-19-2016, 10:16 AM   #4
Redxbob
Redxbob's Avatar
Re: A/C Heat
Does anybody have pics of how low these systems hang under the dash? The fan and box assembly
My build thread 66 c10 swb http://67-72chevytrucks.com/vboard/s...d.php?t=692285
"Forced induction, is that like rape?"
Redxbob is offline   Reply With Quote
Old 01-19-2016, 11:26 AM   #5
64shortbox
64shortbox's Avatar
Re: A/C Heat
Could you please explain why. I bought my truck with Vintage Air already installed by the PO and it works great - never had a problem but I felt if I was going to install a system I would use the Old Air just because of the more factory looking Heat/AC Controls. I never cared for the cheesy plastic A/C vents and did install some A/C vents from a 64 Chrysler that I like Much Better (my opinion only) as stated I've Never had a problem with my Vintage Air system.
64shortbox is offline   Reply With Quote
Old 01-19-2016, 01:11 PM   #6
earl84
Re: A/C Heat
Sorry, no pics at the moment, but I installed a VA system. It took a long time to put in, but it's not horribly difficult. Customer service was great. I bought a deluxe heater control set to use, works great. So it looks absolutely factory except the black plastic part that distributes dash level head/AC that hangs below the dash. I will remove that once corvettejim's side vent balls become available.
As far as working well, it is awesome. Cools well, heats well. The only gripe I have is that the floor vent for the driver side sort of hits my high hump and doesn't blow on my feet very well. I will be adding a small section of heater hose to make it dump there better when I get a chance and motivation.
earl84 is offline   Reply With Quote
Old 01-19-2016, 01:15 PM   #7
Redxbob
Redxbob's Avatar
Re: A/C Heat
I know about the black plastic vent panel but i was curious as to how low the box itself hangs, like would a tall passenger end up kicking it. How does it look and whatnot
Old 01-19-2016, 01:21 PM   #8
earl84
Re: A/C Heat
It doesn't hang low, wish I had pics. I've had my 6 foot tall sons in there at the same time, 3 of us across, no worries about kicking the unit.
Old 01-19-2016, 10:18 PM   #9
64shortbox
64shortbox's Avatar
Re: A/C Heat
Actually the box sits up pretty high. You loose about 1/2 of your glove compartment - probably a little more than half. A new glove box liner is included in the kit. Here's the only pics I have on hand at the moment. they were taken a few years ago. The wires you see hanging down are from when I was wiring foot well lights to my truck that came from a 74 C-10. I just didn't want you to think they were part of the Heat - A/C system. If you want better or more specific pictures of the A/C - Heater Box just ask. I can take some beter pictures this weekend.
Yes, it's the same truck - just a lot of "little" improvements along the way in the years between the time the pictures were taken that no one really notices but me. Tilt Column from a 72 Chevy Van slid as close to the dash as I could get. Billet Flamed steering wheel, 64 Chrysler vents, foot well courtesy lights with door jamb switches, 73 C-10 power brake pedal to go along with the 73 Disc Brakes I installed and the suspended 72 C-10 style gas pedal to match the newer style Brake pedal, windshield washer and now the truck has had the front seat reupholstered, power windows & locks installed. Are these trucks ever done? My wife keeps telling me I spend more time with my truck than I do with her. Sad part is at times I think she's right.
Old 01-19-2016, 11:04 PM   #10
TopFuel1966
TopFuel1966's Avatar
Re: A/C Heat
Old Air heat/ ac unit in a 66 C-10
TopFuel1966 is offline   Reply With Quote
Old 01-19-2016, 11:56 PM   #11
dodgiesdad
dodgiesdad's Avatar
Re: A/C Heat
Here is an in process view of the old air system in my truck. Perhaps having the glove box out will give you a better idea.
Old 01-24-2016, 01:43 AM   #12
sampsmit000
Re: A/C Heat
Is their any that look more original and use the vents above the radio?
Mitchell Sampson
Old 01-24-2016, 02:14 AM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: A/C Heat
I like that. And the dash control panel - you take that apart and have it painted?
I am considering making the dash vents the same way.
Old 01-24-2016, 12:07 PM   #14
Clyde65
Clyde65's Avatar
Re: A/C Heat
Thats the part im not overly happy with is the controls. I too wanted the factory look, although it works, it doesnt work like i think it shouls. Using the electronuc version ( kind of like our trucks heater controls) work better but look nothing like the factory controls.
I also dont like that there isnt any floor heat.
Its in and it works, heat and ac works as it should. I have already replaced the blower motor tho, but its been in for 12 plus years.
The Old Air may be better now but i think the VA systems are better.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-24-2016, 02:10 PM   #15
dodgiesdad
dodgiesdad's Avatar
Re: A/C Heat
Rocknrod - Yes I took the control panel apart to paint it.
Mitchell - At the time I started mocking my dash up I did not know of any other "factory looking" options for vents above the radio so I welded the ashtray hole shut and cut in the two holes for the vents. If I was doing it today I strongly consider one of the center units from corvettejim, they look very original.
Clyde65 - I to did not like the absence of floor heat. Based upon my intended use of the truck I decided it wasn't a big deal for me.
Old 01-24-2016, 02:12 PM   #16
64shortbox
64shortbox's Avatar
Re: A/C Heat
Clyde65,
Thanks for the info. Learning what you know I too would have chosen Vintage Air. I want my floor heat in the winter time - if my feet are cold I'm cold. Thanks for explaining for me.
Old 01-24-2016, 07:09 PM   #17
Clyde65
Clyde65's Avatar
Re: A/C Heat
Your most welcome.
The kicker for me is Old Air is manufactured and sold about 4 miles from my house....
Clyde65
Rebuild of Clyde
support our troops!
Old 01-27-2016, 07:55 PM   #18
sampsmit000
Re: A/C Heat
Any pictures of the Ac from the engine compartment?
Mitchell Sampson
Old 01-27-2016, 10:22 PM   #19
64shortbox
64shortbox's Avatar
Re: A/C Heat
I only have 2 loaded on this computer. This is a Vintage Air system installed by the previous owner. These pictures were taken after I pulled the motor & trans to fix some oil leaks and while I was at it I installed a Lincoln Mark VIII Cooling Fan, a Ford Exploder radiator overflow / windshield washer combo, cleaned & painted the motor, exhaust manifolds, firewall & fender wells and installed the 73 C-10 disc brake set up while everything was out. After all of that I decided it was Margarita Time. Are these trucks ever Done?
