Old 01-18-2016, 07:13 PM   #1
chiro22
chiro22's Avatar
Power Steering gear box and Tie bar help
Howdy,
In the process of giving new life to the beast (1973 Cheyenne) I took on as a project a few weeks ago, the latest issue is the need for a new power steering gear box and tie bar on the driver side. I found a stock on on O'reilly's for $150 and have seen them go all the way up to $700. This is a hunting/fishing weekend truck, will the O'reilly's one do the job or do I need a more heavy duty, higher ratio gear box?
Also which tie rod would work best with the recommended gear box?
Thank you,
Doc
1973 Cheyenne
"I get up in the morning looking for an adventure."
chiro22 is offline   Reply With Quote
Old 01-18-2016, 07:23 PM   #2
slotard
Re: Power Steering gear box and Tie bar help
2wd or 4wd? Ride height? Tire size?
I'd consider a junkyard one or rebuild what you have.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-18-2016, 07:31 PM   #3
chiro22
chiro22's Avatar
4wd, 6' lift and 35s
I think the pick and pull near me just got a 73 Cheyenne, I'll go see what I can grab off of that.
Thank you,
Doc
1973 Cheyenne
Old 01-18-2016, 11:19 PM   #4
slotard
With a 6" lift I'd consider crossover steer. You want a 2WD box for that I think. You need some other parts too.
1973 C20, 350/350
Old 01-19-2016, 12:49 AM   #5
Zane M
The OReilly one will "Do the Job" for your limited use application.
With that said, I would suggest getting a non-re manufactured box if at all possible. Between the mechanic I use to do work I don't have time or knowledge to do and myself, we have seen too many reman boxes take a crap after a couple of years to feel good about using them.
As far as the tie rod, I would personally stick with MOOG or equivalent. while I like working on vehicles, I don't particularly like re-doing jobs sooner than needed. Life expectancy of the cheaper parts is likely going to be a couple of years.
Zane M is offline   Reply With Quote
Old 01-19-2016, 01:57 PM   #6
1redbowtie3
1redbowtie3's Avatar
These guys do excellent boxes .. http://www.redheadsteeringgears.com/
1redbowtie3 is offline   Reply With Quote
Old 01-19-2016, 07:06 PM   #7
chiro22
chiro22's Avatar
Thanks!
Thank you,
Doc
1973 Cheyenne
Old 01-19-2016, 07:07 PM   #8
chiro22
chiro22's Avatar
I'll take a look.
Thank you,
Doc
1973 Cheyenne
Old 01-19-2016, 09:00 PM   #9
lilpoindexter
lilpoindexter's Avatar
I put one from oreilys in my truck in 2012. i have had no problems with it whatsoever..no slop in the center, no flaking coating, I would recommend it.
lilpoindexter is offline   Reply With Quote
Old 01-20-2016, 01:31 AM   #10
chiro22
chiro22's Avatar
Happy to hear it
Thank you,
Doc
1973 Cheyenne
