Power Steering gear box question
Howdy,
In the process of giving new life to the beast (1973 Cheyenne) I took on as a project a few weeks ago, the latest issue is the need for a new power steering gear box and tie bar on the driver side. I found a stock on on O'reilly's for $150 and have seen them go all the way up to $700. This is a hunting/fishing weekend truck, will the O'reilly's one do the job or do I need a more heavy duty, higher ratio gear box? 4x4, 6"lift and 35s Also which tie rod would work best with the recommended gear box?
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
Re: Power Steering gear box question
I bought the one from O'reilley's for my truck and I am installing it at the moment. I did find that the frame had a crack in the frame behind the box. My old box was leaking badly.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
I installed the oreily gear box, no issues so far the steering feels a bit tighter now. But overall the gear box is fine in a stock application.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
