Old 01-19-2016, 12:49 PM   #1
blown240
blown240's Avatar
61 Steering Upgrade - Couple Questions
I am gathering parts to do a power steering swap and a steering/suspension rebuild.
I have a steering box and pump from an 81 C30 with a hyrdoboost. I am not running the hydroboost, so I assume I need power steering hoses from a non-hydroboost truck. Does anyone know what years I should look for?
Also, I am going to get new upper and lower ball joints, inner and outer tie rods, and adjuster sleeves. Anything else I should get while Im at it?
Here is what I have so far:
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 01-19-2016, 01:29 PM   #2
jtrichard
Re: 61 Steering Upgrade - Couple Questions
Looks like 80 to 88 is all the same hose c10/c20/blazer/jimmy ect. you will need to cap off the one return port on the pump as it is not used without the HYD boost
jtrichard is offline   Reply With Quote
Old 01-19-2016, 02:42 PM   #3
blown240
blown240's Avatar
Rock auto shows a first design and a second design for the pressure hose. One is 26" and the other is 31". Should I just get both and see what works better on the 61?
Old 01-19-2016, 04:09 PM   #4
blown240
blown240's Avatar
So Im getting tie rods and PS hose from Rock Auto. I need to find lower ball joints, but the only place that has them wants $140 each! CPP doesn't know when they will have more. They are saying 140 day backorder.
Old 01-19-2016, 07:07 PM   #5
OldChevy61
OldChevy61's Avatar
Lmc showing them at 120.00. Don't know about being in stock. Check eBay as well.
OldChevy61 is offline   Reply With Quote
Old 01-19-2016, 08:12 PM   #6
blown240
blown240's Avatar
Even $120 seems high. CPP has them for $40 when they are in stock.
For now I will swap in the PS parts and do the tie rods. Once thats done ill do the ball joints.
Old 01-19-2016, 08:44 PM   #7
OldChevy61
OldChevy61's Avatar
For lowers? I ended up buying a complete front rebuild off eBay that included uppers,lowers, inner and outer tie rod ends,adjusting sleeves and idler arm for my 62 for around 279.00.
Old 01-19-2016, 09:14 PM   #8
blown240
blown240's Avatar
On Man! Thats a great deal! Ill check Ebay!
Old 01-19-2016, 10:52 PM   #9
blown240
blown240's Avatar
Just ordered what I needed on Ebay! Thanks!! Oldchevy61!!!
This is what I got: http://www.ebay.com/itm/1960-1961-19..._qi=RTM2247625
Old 01-20-2016, 05:00 PM   #10
OldChevy61
OldChevy61's Avatar
Mine was basically the same,only with idler arm included. Not Moog, but for the money,it works for me. Mine went right together,no problems.
Old 01-20-2016, 05:03 PM   #11
blown240
blown240's Avatar
Ya, I saw that one too. I thought about getting it, but I already have an extra idler arm, so I figured I would save a bit of money
