Old 01-19-2016, 04:24 PM   #1
MILLER TIME
Brake swap question?
I have a 12 bolt rear end out of a like 71 c10, my question is, will the drum brakes off of a mid 80's 10 bolt c10 fit on my 12 bolt? I was going to do a disc brake kit but I don't think I am going to be able to since I am installing c clip eliminators. Any input is greatly appreciated.
Doin Work! Little At A Time....
MILLER TIME is offline   Reply With Quote
Old 01-19-2016, 04:35 PM   #2
ERASER5
ERASER5's Avatar
Re: Brake swap question?
Yes, if you also use the mid '80 backing plate. At some point GM started using 2-1/2" deep brake shoes and drums. The wheel mount did not change, the backing plate did. It will run deeper than earlier trucks.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-19-2016, 05:08 PM   #3
MILLER TIME
That's what I needed to know! Thanks.
Old 01-19-2016, 10:12 PM   #4
volksworld
for a while brothers was selling a kit with wider shoes so i figured they must have been stock later model ones...got mine off an 85 van...the e brake cable on the rs wrapped around and entered the backing plate from the rear...so i had to weld up that hole and drill a new one in the front...the stamping was symetrical so the spot to drill it was there
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
