79+ Bedside to 77- Truck
Can you do this ?
Re: 79+ Bedside to 77- Truck
You can but the cutout portion of the bedside is a little larger on 79 and up. The hump in the floor to clear the gas filler hose is smaller on the 78 and down bed floors and will leave a small 3/4-1" gap between the bedside and the hump. You could weld a patch from the old bedside to the new one and it would look fine after that.
Born and proudly residing in a Red State ! |
At the body shop.
True statement, I have 85 quarters on a 73 floor. Other than the minor gap at the filler, absolutely bolted on.
There is a weld at the rear stake pocket, when you bolt it all back together put the tailgate on to set the gaps. Tighten bolts with required gaps then weld it.
" That didnt make it any newer " " Dont antique the equipment " |
At the body shop.
![]() Like this.
Thanks guys love this board
15x8.5 and 10 inch Convo Pros. I had a set of those at one time with 275/50 fronts and 295/50 rear tires. It was the thing to do then. I still like them
I picked this 77 last week end for 1000 bucks Putting a 4-6 drop 350 with a th350.Dont really like the wheels they got to go.
