Old 01-19-2016, 10:50 PM   #1
Burbnasty
1970 K-20 front brakes.. again what to do?
I know this topic has been covered several times, and I have read through several of the previous posts.
I have a 1970 K-20 350 motor, 4 speed trans (granny gear) with power front drum brakes, I have ordered brake parts form several different places and keep getting wrong parts.
At this point I can pretty much only get shoes for the front, The wheel cylinders keep being wrong parts, I cant find the correct hose, and I didn't even try to find drums, because from reading it seems they are impossible, or very expensive to find.
I understand that the next best option is to get a front disc conv. (also expensive) or swap axles all together.
I saw a small tag on the front dif that says 4.09. does this mean I have 4.10 gears in the back?
If I am looking for a replacement axle do i need to find a 4.09 or can a 4.10 work?
If I do find an axle what else will i need to change to make the truck drive down the road? i have seen several different things contradicting things.
I think I have a dana 44 does this mean I need to replace it with a dana 44 or can a 60 work providing I find one?
What should I do here guys I want to do this correct but I also don't want to open a can of worms and spend a bunch of money, If i could find all the parts I would just go with the original set up, but if I am going to just have to face the inevitable at some point and do the swap I guess it may as well be now.
Suggestions?
Burbnasty is offline   Reply With Quote
Old 01-19-2016, 11:00 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 1970 K-20 front brakes.. again what to do?
Anything gm from 71-87(91 blazer, jimmy, suburban, 1 ton crew) will bolt right in and have disk brakes. Up to 76/77 will be a 44 after could be a cooperate 10 or a Dana 60 depending on what It comes from. 4.09,4.10,4.11 are trivial differences and can all be interchanged. Dana 60 is a go as well if you can find one, king pin is most desirable. Dodge dana 60 from a first gen Cummins will bolt in as well from what I've read.
Tyler
57taskforce is online now   Reply With Quote
Old 01-20-2016, 10:30 AM   #3
68350
68350's Avatar
Here is a part number for front drums. The part number I believe comes back for a Dodge drum but it is the same part and its cheap!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 01-20-2016, 10:32 AM   #4
68350
68350's Avatar
Also I believe you can get a rebuild kit for the wheel cylinders. Rent a hone from O'Reillys for free too.
Old 01-20-2016, 11:55 PM   #5
El Dorado Jim
like 57Taskforce said, go find a dana 44 from a newer chevy or gmc, they will bolt right in and disc brakes are alot better than drums....you will have to change master cylinders , they are different for disc brakes but worth the trouble doing the conversion
El Dorado Jim is offline   Reply With Quote
